Results 106 to 109 of 109
Thread: Thoughts of adding strakes
07-17-2017, 08:19 PM #106
Over the summer of 2015 I lost most all use of my right arm, surgery late in the year did me real well. Spring of 2016 my business took off again and to date I have not even pulled the winter cover off my boats. I look at them wishing but just have not done anything.
I have bought an electric fuel pump to install near the tank with expectations that may be the engines power limitation. Then I can get back to developing the hull. But for the time being I am stuck in the shop with more work than I can keep up with.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
07-17-2017, 08:39 PM #107
07-17-2017, 08:51 PM #108Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Good to hear things are improving. I was thinking about this thread lately.
02-11-2021, 04:56 PM #109
It is clear I have not been here in years. My should issue seemed good right after surgery. Issue that persisted is if I try to pull on a wrench or bend over to lift anything the shoulder dislocates forwards. Turns out part of the surgery was removing 70% of my AC tendon. I did not place much thought to that but what remains was stretched out allowing instability. In late 2019 I thew in the towel on trying to be productive and trying to keep my business going. Since backing my workload down the shoulder only now is becoming stable. Still can not sit back or lay on my back cause the should will not allow that pressure, Oh well. So for me, my mid 60s arrived and I let SS start feeding the bank.
Update on my boat.
Early 2020 I uncovered this boat and launched it on my pond. I had never properly pickled it a half a decade ago. Turns out it was not hurt by that. Not that I can tell at least. I had only clipped on an EarthX jump pack. The Excel was kind of tight turning, I had pulled the plugs and sprayed some oil in each cyl. I fired it on a hose and then to the pond we went. It felt good to just motor about. The pond was low, not common for the spring so I did not have much room. It was nice though. I trailered it, vacuumed all the flotation foam bits the mice had spread about and put it away again. It was happy and sad but I look forward to what this year will offer for actually getting on the water. Time to make changes to the fuel system to see if fuel restriction is the engines limiter or what I am up against. I am also thing I want to make changes to the pad I had built and add a step providing more lift and a wider surface to balance on. I can not plan much of a work load since I have designed another airplane and am build that. Got to keep the mind active.Regards,
Charlie North
