Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
    Sep 2014
    Cedar Park, TX
    1984 Mercury V6 150 Outboard Problems - I am stuck
    I want to thank everyone on the forums as I have read many, many of the helpful posts and have learned a lot in the past few months about outboard engine operation and repair.
    Quick Primer: I am pretty technically experienced, but my new experiences with Outboard motors is testing my skills and patience lately. Thanks to many of you on the forums, I was able to tune up, repair, and setup a 1989 110 Evinrude for my 30ft pontoon boat and am very pleased with the motor now.
    My new problem is a 1984 Mercury V6 150 Outboard that I got in another boat transaction. I located a 1996 Procraft 180DC bass boat and put them together. Prior to mounting the engine on the boat, I thought it was running pretty good, but my first water test has me stumped now.
    Engine Background/Setup:
    • Mercury 150 V6 1984 - Serial Number: 6480926
    • unknown hours
    • on a 1996 ProCraft 18' dual console bass boat
    • no jack plate or set back
    • Cavitation plate even with the bottom of the hull
    • 21 pitch aluminum prop (had a 19P, but prop guy told me to start with this one for testing)
    • No oil injection - mixing 50:1
    • Carbs are all 3: WH27-1
      • stock jets I think: .054 and .064 sized
    • Spark Plugs are BU8H NGK
    • added dual steering bracket (works good)
    • single piston trim style (re-built pump, works good)
    Work Done so far:
    • New water pump
    • New thermostats
    • New poppet valve/kit
    • Rebuilt fuel pump
    • cleaned all 3 carbs and put in new kits
      • did not change floats, has plastic ones
      • did float test, floats are not holding water
      • Kit included all gaskets and needle/seat
      • set floats to be even with float bowel body when held upside down
      • Blew into fuel line to test needle seal when upside down, passed test
    • New Spark Plugs (BU8H NGK)
    • New Coil wires (checked firing order to wiring diagram - ok)
    • New Stator
    • New Rectifier
    • New Trigger
    • New Starter and wires
    • All new fuel lines, priming bulb, and water lines
    • Added a spin-on water separating filter between tank and motor
    • New cranking battery showing 12.90-13.4 volts (kept charged frequently)
    Problem:
    Unloaded (just me) on the water in forward gear, I put down the throttle and the engine only gets up to 1800-2000 rpm's and boggs down like the boat weighs too much. It will not get on plane or produce any power. I have tried working up the throttle slowly, but that does not work either.
    Here is everything I have tried:
    • Compression test - from 1-6 - 90, 90, 100, 100, 100, 95
      • tested with rental compression tester - put on my air compressor and readings were showing 10psi too low compared to compressor
      • so, my thinking is that the readings really should be: from 1-6 - 100, 100, 110, 110, 100, 105
    • Spark air gap test - all 6 cylinders get a 1" gap spark, bright blue and nice "snap"
    • I also put a timing light on all wires while cranking, light is steady and consistent
    • Set timing according to book:
      • using timing light, all plugs 2-6 out and grounded, air gap tester on cylinder 1
      • throttle at WOT, full advance to stop, cranking speed set to 18 BTDC
      • throttle at rest, cranking speed set to 11 ATDC
      • Carb linkage roller spins freely, not touching cam at rest
      • all carb butterfly's closing completely at rest, opening/moving in sync
    • Ohms on new stator are within spec (used CDI troubleshooting guide
    The engine starts up and runs great on the hose and on the water. I can rev it up to 5,000-6,000 RPM with no hesitation. When the engine boggs down, I have tried pumping the primer bulb (nothing changes), but when I hit the enricher/primer by pushing in the key the engine dies. The engines smokes considerably as well. I do have a little fuel sitting in the front of the carbs (pictures below), but I don't know if that is leaking there when trimmed up for trailering or from running the motor on the water.
    I could really use some help to point me in the right direction. I have a feeling I just need to adjust my throttle pickup a little more to get everything in sync. I have read the timing setup/link and sync at least a dozen times and I still don't think I have a fundamental grasp of what pickup timing is or what the goal is for it. I have read that the butterflys on the carbs should not begin to open until the timing is fully advanced? Not sure if that is true.
    Sep 2014
    Cedar Park, TX
    One thing I forgot to mention was the bleed lines. I have not touched them since I started working on the motor. I am going to replace them all today and see what happens. Any chance that those lines could be causing or contributing to the bogging issue?
    I have also not touched or inspected the reeds. Thoughts there as well related to bogging?
    Thanks everyone.
    Aug 2009
    NJ
    I could be way off here but from my engine experience I've noticed when things run fine under no load, but die under load it was a carb issue.
    Sep 2014
    Cedar Park, TX
    Thanks Stig, I already rebuilt the carbs very carefully and put in new kits, but I am going to set the floats a bit higher to see if that makes a difference. I originally set them so that they were dead level with the float bowl wen turned upside down, but I read several places here on the forum that you should set the far side (away from the hinge) so that it hangs down just a bit further than flat level.
    I also purchased all new bleed lines. I will replace those today and check all the bleed check valves as well.
    Any other ideas are appreciated.
    You are still getting too much fuel. Go thru the carbs again.
    Sep 2014
    Cedar Park, TX
    Thanks everyone. Anything I should look for when looking through the carbs again? I am going to set the floats a bit higher for sure. Does anyone think that an improper link and sync could be putting too much fuel into the engine faster than it can compensate with timing?
  7. Likes jass1961 liked this post
    NEVER, EVER rev that motor to 5000-6000 rpm on the hose Bad things can happen.
    Does this thing still have the advance/retarded(intentionally misspelled) modules still installed?
    Sep 2014
    Cedar Park, TX
    By "bad" you mean other than making my neighbors really irritated right? Duly noted won't do that again.
    yes you make a good point I forgot to mention I removed the idol stabilizer before I did anything. And left it disconnected on the advice I found on this forum.
  10. #9
    Might be fighting a losing battle here, compression is pretty weak. I'd go back to the 19" prop and bump the max timing to 21° and see how it acts.
    Sep 2014
    Cedar Park, TX
    Got the carbs off and all the bleed lines replaced. Checked each line I took off by blowing in one end, covering the other end, all under water. All the lines tested ok (no bubbles). I also tested all the check valves and they all tested good except for one. The one is on the air box. I am not 100% this is a check valve, but if it is, it is not working as I can blow air throw it both ways by mouth.
    Here it is, is this supposed to be a check valve or a pass thru fitting? (the one to the right of the fuel line)
    Took a look at the Reeds while I had the carbs off. They all looked good to me. No nicks or scratches and all seemed to be seated nice against the block.They all looked like this:
    As for the carbs, I have always heard to set the floats so that they are even with the float bowel body. This is how they were when I took them off. You can see that they are actually just a bit below the body.
    I adjusted them a bit to be even so that they can't be seen from a direct side view.
    Anyone know which method is correct? I would like some advice before I put them all back on the motor.
  12. #11
    Sand Springs,OK
    Quote Originally Posted by something2do View Post
    Loss of power under a load,equates to misfiring. Suspect one of your switch modules,check fire to each cylinder.
  13. #12
    Carb floats should hang out 1/16", first pic looks pretty close.
    Plainville, CT
    If you're using an infloor fuel tank maybe I'm wrong but trying an external fuel tank will eliminate any restriction issue.
  15. #14
    Pekin, IL
    I think Pete hit the nail on the head with his compression comment. Try that smaller prop and see what happens.
    Rock
    Team Junk
  16. #15
    On the carb pics, look at all the fuel sitting around the bowl vents. It sure looks like it is puking fuel from flooded bowls. jm1/2 cent.
