Results 1 to 15 of 29
Thread: A23 ecu
08-18-2014, 12:35 PM #1
A23 ecu
Just bought a '99 225 pro max with an A-23 ECU havent had any luck finding information on it, any at all would be greatfull
I think its off a offshore SS model
08-18-2014, 03:11 PM #2
The A23 came on the SS 15" 225PM only. One piece plate with the mini oval tuner.
08-19-2014, 09:10 AM #3
Guess I wasnt clear, Im wanting more information on the ECU its self. Can any one tell where I can find this info or have knowage of the ECU they would care to share
thanks
08-19-2014, 09:14 AM #4
What info are you looking for? Mapping? Only Mercury can provide that...maybe or Eric Simon.
08-19-2014, 03:02 PM #5
rev limit?
08-19-2014, 07:05 PM #6
08-20-2014, 07:01 AM #7
Thanks for your info tux
08-21-2014, 12:09 PM #8
my dyslexia was showing, its really an A32 which makes me happier, 8200 limiter
08-21-2014, 12:44 PM #9Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
nope all 225 promax limiters are 6750. unless someone has tweeked on it. i have had several of these stock 225 Promax brains some of them are good some are not
08-22-2014, 08:00 AM #10
11350 A 32 came off a 1994 Off Shore race 2.5 with a 39 psi fuel curve and a 8200 rev limit.
08-22-2014, 08:00 AM #11Part #Ver.Model & YearPROM IDFuel PressureRev. LimitsSupercede ToSupercede FromNotes
11350 A27 Early 2.5L Analog ECU used on engines with external TPI and external Speed-Limiter (Rev-Limiter) modules. (6) A29 2.0 / 1994 N/A 39 11500 A45A45 2.0 / 1995 2615 56 11150 A46 2.0 / 1995 2615 56 11150 A28A53 2.0 / 1995 Service Only 2613 / 2650 56 9250 A40 2.4 2514 39 7700 821559A1A32 2.5 Offshore Race / 1994, N/A 39 8200 A35A36 2.5 Offshore Race / 1995 2509 39 8200 A32A48 2.5 Drag / 1995 2511 39 11500 A38A63 2.5 Drag / 1995 + Up 2719 / 2796 56 11500 A33 S3000 / 1994 N/A 39 9250 A52A47 S3000 / 1995 2508 / 2522 56 9250 A52 S3000 / 1995 2508 / 2522 56 9250 A33A61 S3000 / 1996 2717 / 2776 56 9250 A65 2.5 PROP / 1997 2622 56 8600 A49 2.5 EFI / 1996 2510 39 7750 A37A62 2.5 / 1996 7750 Digital ECU with internal TPI. Similar to the A49. (6) 849849 A2 2.0 Mod U 7115 56 none / 11500 A45The 849849 series superceded the 11350 series, and features a thinner ECU, different tester connector, enrichment moved from front to back of box, ECU chips are potted and cannot be removed. A3 2.0 PROP 7113 56 9300 / 9400 A53A4 2.4 7114 39 7500 / 7800 A40Not original equipment on any 2.4L - replacement part only. A1 2.5 EFI 7110 39 7600 / 7900 A49A5 2.5 ROS 7109 39 none / 8200 A36A6 2.5 DRAG 7119 56 none / 11500 A63A7 S3000 7108 56 9350 / 9650 A47A8 S3000 7117 56 9300 / 9400 A61A10 S3000 PROP 7323 56 8650 / 9100 849849A9A13 DRAG 2001 56 11500 A14 S3000 S001 56 10100 824003 -1, A1 200 2.5 XRi / 1994-1995 E683 / E556 -2, A2 175 2.5 XRi / 1994-1995 A7CO -4, A4 150 2.5 XRi / 1994-1995 E57A -5, A5 200 Pro Max / 1995 8714 -6, A6 225 Pro Max / 1995 C9C2 / AD49 -7, A7 150 Pro Max / 1995 A470 -8, A8 200 2.5 XRi / 1996 5AA0 / 4227 -9, A9 175 2.5 XRi / 1996 436F / C2A0 -10, A10 150 2.5 XRi / 1996 1BB6 / 24C5 -11, A11 200 Pro Max / 1996 A287 -13, A13 150 Pro Max / 1996 3E97 -14, A14 175 XRi, 1991 67E4 -15, A15 200 Offshore / Service 1831 A16 200 XRi / 1991 C5D9 A17 225 Pro Max / 1996 5E62 A12The A12 was recalled for recallibration A23 225 Pro Max 15DSH / 1998, 225 Pro Max SS 2E88
08-22-2014, 08:37 AM #12
The 11350 did not come on a 225 Promax. The only O/S 225 PM was the 15" SS motor and it came with the A23 box for a reason...Be careful read very carefully!!
I wouldn't personally recommend spinning a stock 225PM at 8000+...JMPO.
08-22-2014, 12:28 PM #13
it would appear that this is a replacment ECU then,
the rods have been balanced and pistons have been top pinned, block has had the oil drive void filled and the the fuel is pre-mixed at the tank , so its not a stock 225PM, all this work is by JSRE
08-22-2014, 01:08 PM #14
IMO you should be Just fine. There is probably some Port and chest work done as well!!! If Jay worked that motor it should be a Beast.
08-22-2014, 02:01 PM #15Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
not a promax ecu then its a260 ecu, just reading your post it sounded like it was a 99 promax with a A 23 ecu, not a tweeked on mota
