Results 1 to 3 of 3
    fort lauderedale
    parting out 2 ficht 25 inch engines adaptor,complete midsection $250.00 will ship
    Gotta' clean the shop have 2 - 25-inch ficht midsections assembled steering arm motor mounts, iner and outer exh no trims the whole mid minus the trim,powerhead and gearcase
    so both of these for 450$ i will strap on a pallet for shipping
    10 good ficht pistons 20$ each good big block crank 250$
    intakes with reeds top or bottom 50$ each
    emm and big block 90 degree injectors on the heads all 6 with emm 200.00
    got the oil injector 40$
    flywheel 50$ block needs 1 bore 100$
    thats the fichts joel 9547637729
    What year/hp are they?
    fort lauderedale
    ficht parts
    hello one is a 1999 big block the other is a 2001 big bore big block
    we opened them up to check the cranks both are good the older one scuffed a piston the big bore has all 6 nice pistons, rods big end rod bearings we probably could of left it assembled but now we know for sure I have to move in a couple weeks and cannot take everything the 2 25 inch mids have good mounts adaptors its all good... would take 350.00$ for both mids..I might be wrong so correct me....that a ficht block is 1/2 taller than a regular looper so if you try to use a regular looper on a ficht mid you have to change the shift shaft and driveshaft to the ficht parts.
    now if you got the mids you could get one of them cut to 15 inch
    anyhow thanks for looking and if you were in fla and wanted all of this for 1 price I could meet you at..sebring or somewhere up the road a bit to make it easier than your coming all way to fort lauderdale................ i'll bring my 16 maltese magnum and find a place to run we could meet at cadillacs on the cross fla waterway and runback behind his house where off 2010 and off 2011 were!!!
    joel 9547637729
