Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 66
    Dec 2001
    what limits RPM?
    I am thinking about starting w/ a Merc 200 and building a motor, I know the ecu controls the rev limiter on an efi motor, but on a carb motor what limits the rpm? i'm thinking of buying an old motor and just seeing what I can build and this was my first question. thanks
    St. Petersburg, FL.
    On my engine and most other carb. outboards the power pack/s limit the maximum rpm the engine will obtain. In my case it is 6700 and at this rpm the power pack starts cutting out the fire.
    "BULLETMAN" The Sunshine Syndicate
    20V Bullet/225 Johnrude
    Dec 2001
    I am trying to build my first "performance" motor, is there ways to get around the limiter in the power packs, and would it require different rods and pistons to hold up to the rpm's
    St. Cloud, FL
    There is no such thing as a revlimiting power pack (switch box) on a carb motor.
  5. Likes powerabout liked this post
    Home
    I think whats happening is the switch boxes have reached the limit of their design. Doesn't rapair exist for pretty much this reason?
    I seem to remember it being said that the switch boxes become saturated- for lack of the right term, and there is a higher end one. Is this the diff between 260 electronics and 280?
    Also US-1 doesn't seem to have this limited problem with the carbed engine he builds, at least I don't think so.
    '90 STV
    '96 260
    under construction
    for far too long
    no switchbox on a 2.0 2.4 2.5 is limiting the rpms
    only thing that does limit your rpm on a carb engine is the spark advance module on the engine (not all the engines have them )
    it is one of the black boxes on top of the engine
    and it is limiting the spark advance at high rpms
    disconnect the box en set timing at 25 degrees
    will help you too rev higher
    bye
    Sep 2002
    PSL, Florida!
    Exclamation um yes there are
    there are rev limiting power packs. both my OMC's have them. but I'm not shooting for the warp speeds that would require them removed.
    Don't lick my boat, It makes it sticky!
    Another Hitman for the Sunshine Syndicate!!
    2011 Seafox Viper
  9. #8
    Mar 2002
    Middlefield, CT
    rev limiters
    IF THIS A CDM MOTOR, THE REV LIMITER IS IN THE CONTROL MODULE. ONLY THE CARB CONTROL MODULES HAVE THE REV LIMITERS IN THEM, NOT THE EFI. YOU CAN INSTALL THE EFI MODULE ONTO THE CARB MOTOR TO ELIMINATE THE LIMITER. YOU WILL ALSO NEED TO REPLACE YOUR PLUGS. GO FROM THE BU8H'S TO THE BUZH NGK'S. HOPE THIS HELPS, MIKE
  10. #9
    Kissimmee, Florida
    TMerc
    Tracy, we've had this discussion before. Just take a look at any Rapair book. OMCs are often limited from the factory.
    Rickracer
    Sunshine Syndicate Member
    There is a fine line between "hobby" and "mental illness."
    [img]http:/
  11. #10
    May 2001
    Los Angeles Ca
    Merc carb motors don’t have rev limiters. The port timming is what keeps the RPM down.
  12. Likes gmorgan liked this post
    Houston Tx
    Yep US1 knows
    the duration of the exhaust port is what determines the Max RPMs of any 2 stroke motor.
  14. Likes gmorgan liked this post
    St. Petersburg, FL.
    I guess the "6700rpm" was just painted on the side of my powerpacks for ****s and giggles by some moron at the factory. I was not familiar with the Mercury, but that is the way things work in the world of White and Blue.
  16. #13
    Houston Tx
    yep johnnyrudes are different
    they have rev limiters in the power packs Rapair sells packs with the limiters removed I would think Rickracer should step in here and tell you how he can save you money on them. OMC's are long rod long stroke motors so they tend to make more torque and horse power at lower rpms. nto to mention the pistons weight a ton compared to a Merc. I think the old cross flows had pistons that wiegh 650 grams, that is a lot of metal to be slinging around.
  17. #14
    Kissimmee, Florida
    Cool Well Greg
    Sometimes I forget, and I don't want to beat people over the head with it either.
    Rickracer
    [img]http:/
  18. #15
    Feb 2003
    Tumwater, Wa.
    Question Re: Yep US1 knows
    And perhaps, the load ?
    sasbenson
