Results 1 to 13 of 13
    Jul 2014
    Ohio
    2014 Checkmate Pulsare 2400 top speed help...
    Hello fellas... First post here(great site!). I just bought a 2014 Checkmate Pulsare longdeck from Dean at Checkmate. (Pics from Miami boat show below)
    https://www.facebook.com/media/set/?...4505374&type=1
    I was Looking for some guidance here regarding its top speed as I was told that it was a 73-74 mph boat from the factory. It has a 300XS on it with a 4 blade Trophy Plus (25 pitch- I think) prop. Motor is "broken in" now...with about 13 hours on it...and I can only seem to hit 63-65mph (gps)... With me and girlfriend...and a 1/2 tank of gas in it...with ideal (smooth) water conditions. I Live in Ohio, so altitude shouldn't be an issue.
    After doing a fair bit of searching/reading on the Pulsare 2400 and watching "Wildmans" videos on this boat, 73-74mph seems consistent.... So I am scratching my head a little as to why I am 10mph down on that.
    Any suggestions? Seem right? Prop change suggestions? Motor still need more time? Any magic pixie dust?
    if I posted this in the wrong section... Please let me know.
    Thanks in advance!
    Biloxi,MS
    Here's what I've found: 19" setback, 2.5"-3" below on prop shaft, 28 Bravo one labbed or 27 tempest worked gets me 78.1. Usually runs 75-76 w/2. 25 trophy with 5 people, full tank and 3 Ice chests I've seen 70. Hope this helps.
    -Past:
    1978 Glastron GT-150
    1991 Allison XR2002
    1996 Triad V-21 ski
    2000 Allison SS 2000
    1996Allison GrandSport w/280 Merc
    2005 Hydrostrem Venom Comp w/280 Merc
    1989 Boston Whaler Mischief W 70 Yamaha
    2009 Checkmate Pulsare 2400 w/300xs
    1982 Allison Gt 20(total restore) w/200 XRI
    http://forum.allisonowners.com/showthread.php?t=11151
    2000 Allison GrandSport w/ 280SS
    -Present:
    2022 Allison XB21 Prosport SUB w/ 280 SS
    Feb 2007
    lily lake WI
    Check with Randy aka Wildman he makes them fly
    Jul 2014
    Ohio
    Thanks Double-J !!! (And thanks for such a quick response)
    Appreciate the guidance.... Certainly gives me a blueprint to work from.
    3 quick follow-ups, and Based on your experience:
    1. Does moving from my current 10" Jack plate to the 19" that you suggest make a measurable difference? (Sounds like answer is YES). Also, any stress issues on the back of boat running that much setback?
    2. The 28 Bravo or 27 Tempest that you mentioned... Are those 3 or 4 blade?
    3. I will have to measure how far below my prop shaft is... It's however it came from factory(no idea). Do you recall what yours was "before" you adjusted to 2.5 - 3"?
    I hope with these changes it will start to close the gap a little here.
    Thanks again for your steer my friend.
    Jul 2004
    Connecticut
    As was said, Wildman is pretty much the set-up expert on those Checkmates.
    Mar 2002
    N.E. Ohio
    Quote Originally Posted by RDAglock View Post
    Thanks in advance!
    What part of OHIO?
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
    Jul 2014
    Ohio
    ...central Ohio. Primarily boat at Buckeye Lake. How about you?
    Jul 2001
    Finger Lakes Region, NY
    Randy aka: Wildman knows more about the setups than anyone. Give him a call.
    Ing
    Semper Fi!
    Sold the Talon
    Sold the Pantera
    Sold the Renegade
    2022 Monterey M65
    "Yup...I'm old"
    Biloxi,MS
    1. Never ran it with 12" setback. Did run it with 17" than 19" and didn't notice that much of a difference between the two. No stress issue on transom.
    2. Bravo 1 and Trophy is a 4 blades and Tempest is a three blade. Four blades bite better but the three blade has a little more top end I found.
    3. No I have no idea how it was from factory. Started around 3" and went up from there.
    These are my findings and I'm sure someone else will have some other props they have ran with success.
    -Past:
    1991 Allison XR2002
    1996 Triad V-21 ski
    -Present:
    Feb 2003
    Rochester, NY
    RDAglock,
    For some reason, nobody has asked you what kind of RPMs you're running with your current prop. That's actually pretty important.
    Another thing that comes into play - and is much harder to quantify - is how much trim you're using to get your current speed and RPM numbers. Most Checkmates that I've driven seem to like a good deal of positive trim to wring out every last MPH. Driving a boat with a lot of positive trim takes some practice though. I can tell you that the last 10 MPH or so in my boat is all done with trim.
    1992 Progression 22
    Mercury Racing 250R
    Jul 2014
    Ohio
    Thanks again Double J.
    TooStroked- I believe I am somewhere around 5600-5700rpm. Regarding trim...fair question. I am new to non-jet boats. However, I have been playing with it quite a bit and feel fairly confident that I have found the sweet trim spot right, and right be it starts to throw some pretty big rooster tail..and starts to slow.
    I am starting to wonder if this is truly a mid 70's boat as described. I don't kind tweaking and tuning a little....but 10 mph is ALOT to make up.
  12. #12
    Jul 2014
    Ohio
    Btw TooStroked.... Love the quote at the bottom of your signature. Funny stuff
  13. #13
    Mar 2002
    N.E. Ohio
    Northeast, by Canton. There's a few guys on here that are from the central Ohio region and run Buckeye Lake
    Polaris PRO785
    Bennington 255LCC
    September 2005
