Page 5 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 61 to 75 of 284
  1. #61
    Rhode Island
    Quote Originally Posted by b_rad4tuna View Post
    Thanks for the update! You have clearly taken your time with this project, it looks fantastic! I have been both a mechanic and a welder at a local shop here in utah for the last 6 years and have been itching for a fun project. I have been researching homemade boats and your project has inspired me to now make a cat. Where did you come up with the basic dimentions? Keep the updates coming!
    Thanks everyone ! ! !
    Rad4tuna - I changed things up quite a bit. Originally I wanted it 18' long. Looked at cost of materials, and for an experimental project, it was too much in my opinion. So, I scaled everything down to 2/3 size (12'). Then looking at it more, i added an extra 18" behind the seat. I have a couple pictures of designs I had a couple years ago - - - All of which were BAD haha. (SEE SOME PICTURES ATTACHED TO THIS THREAD)
    Originally, I had it planned out that the driver was too far back in the boat for CG. Then, the decreasing tunnel depth was an issue (common misconception to the ignorant). The secrets of tunnel hull design book opened up my eyes a lot. Much of the dimensions were from basic "Good-to-the-eye", and some others were "ut-oh... that won't work".
    I had inspiration from Glen-L designs, and the 13' Biel owner here on this forum.
    HOPEFULLY GETTING WET THIS SPRING ! ! ! Tax returns will get me a brand new E-Tec (90 or 115... undecided for weight).
ID:	313177Click image for larger version.
ID:	313178Click image for larger version.
ID:	313179Click image for larger version.
Name:	side view .jpg
ID:	313180Click image for larger version.
Name:	Boat Layout.png
  2. #62
    Rhode Island
    Fairing the hull bottom prior to glassing. I hate sanding and filling and fairing. Anyone wanna do this part for me?! Haha
  3. #63
    Blaine, TN
    Long Boarding is were its at on a wood boat, done it too many times to want to ever do it again Enjoy
  4. #64
    Rhode Island
    Fairing up the bottom - - - Complete !
    LOTS of sanding.
    While sanding around the planing pads, I noticed I didn't get good penetration/saturation into the fiberglass, and it delaminated. (see 4th picture). Anyone know what would cause this?
Name:	Faired bottomm.jpg
ID:	314228Click image for larger version.
Name:	faired bottommm.jpg
ID:	314229Click image for larger version.
ID:	314230Click image for larger version.
ID:	314231Click image for larger version.
Name:	Faired bottom.jpg
  5. #65
    Rhode Island
    Starting fiberglassing this weekend. Doing the layout tonight.
ID:	314235Click image for larger version.
ID:	314234Click image for larger version.
ID:	314233Click image for larger version.
ID:	314236Click image for larger version.
  6. #66
    Houston, TX
    Great job! She's alive!!!
  7. #67
    Blaine, TN
    Quote Originally Posted by home made tunnel View Post
    LOTS of sanding.
    Could have been a trapped air bubble or just not good enough saturation. did you wet the surface then apply the material? or apply material then try to saturate through??
  8. #68
    Dec 2014
    Gainesville, Florida
    Nice project!
  9. #69
    Rhode Island
    My father, girlfriend, and a puerto rican friend all came to help ! ! !
    Soaking through 2 layers of 6oz glass on the bottom was a PAIN IN THE ARSE ! especially on the negative corners (corners of tunnel, and outboard sides of lifting pads).
    3rd picture was my Candid Camera shot lol.
ID:	314449Click image for larger version.
ID:	314450Click image for larger version.
ID:	314451Click image for larger version.
ID:	314452Click image for larger version.
  10. #70
    Rhode Island
    Bottom surfaces have 2 layers of 6oz cloth. Sides have a single. Transom has 2 layers also. I took a picture of the worst spot for bubbles - - - No idea what was happening. Tried plenty of resin to soak through, the ribbed resin rollers to push it down, nothing was working for these bubbles. Maybe there was some oil on fingers or something preventing adhesion. Either way, I'll have to sand out these bubbles, and fill them in. I also am going to be filling the trailing edges, and sanding them to a sharp angle prior to painting. They're rounded right now to pull the fiberglass around.
    I'm the ugly mug in the tan shirt -
ID:	314455Click image for larger version.
ID:	314454Click image for larger version.
ID:	314456Click image for larger version.
ID:	314457Click image for larger version.
  11. #71
    Great to see the "crew" gettin into it! Helps remove some of the tedious time. Gary
  12. #72
    Rhode Island
    And more drinkin time for me ! haha
    What would have taken me all day, we did in 3 or 4 hours
  13. #73
    Blaine, TN
    Your MX Helmet blends in with your Barney Curtains Lol
  14. #74
    Rhode Island
    Hahaha - I was wondering how long until someone noticed the dinosaur sheets - They are my barrier to keep that side of the garage warm hahaha
  15. #75
    Rhode Island
    Got three coats of high build primer on! Some more sanding, filling, and we'll be ready for gelcoat.
ID:	322839   Click image for larger version.
ID:	322840   Click image for larger version.
ID:	322841   Click image for larger version.
ID:	322844   Click image for larger version.
