Page 4 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 46 to 60 of 284
  1. #46
    Rhode Island
    Quote Originally Posted by FrenchPhil View Post
    Sweet, what filler material do you use for your fillets.
    Just the dust I swept up from making my scarf joints. So the filler is light weight African Okume mahogany just like the boat
  2. #47
    Sep 2007
    Peterborough, Canada
    PM Sent Home Made.
    Very cool project, BTW!!
  3. #48
    Jan 2015
    Salt Lake
    Looks good!!! Any updates on the progress?
  4. #49
    Rhode Island
    Lots of updates ! Built the trailer from scratch, got it galvanized, and started the pads on the bottom.
  5. #50
    Rhode Island
ID:	313042Click image for larger version.
ID:	313043Click image for larger version.
ID:	313044Click image for larger version.
ID:	313045Click image for larger version.
  6. #51
    Rhode Island
ID:	313047Click image for larger version.
ID:	313048Click image for larger version.
ID:	313049Click image for larger version.
ID:	313050Click image for larger version.
  7. #52
    Rhode Island
    Features - Swing tounge, all LED lighting, 2000lb Torsion axles, 16" Aluminum mag wheels, 245 wide tires, steel diamond plate walkways -
    Total price to build the trailer was approximately $2500-3000. Not sure, I haven't totaled up the receipts.
    The 3 wheels & tires (spare not shown in pics) was $700 alone. Torsion axles $300. Steel was $450. Galvanizing was ironically also $450.
    All the other stuff adds up - Fenders, lights, receiver, hardware, carpet, bunks, winch, etc.
    Took a few months to build, but back to working on the boat ! ! !
    AND YES, I KNOW HOW TO WELD ! ! ! See below :
  8. #53
    Rhode Island
ID:	313053Click image for larger version.
ID:	313054Click image for larger version.
ID:	313055Click image for larger version.
ID:	313056Click image for larger version.
    Started the pads for the bottom - Getting this cut perfect was VERY difficult. A lot of measuring / adjusting / etc. I had to do a double cut on the table saw, 1 from both sides. Getting the cuts to match up perfectly was the hard part. The better the cut, the less sanding !
  9. #54
    Rhode Island
    So here in New England, it's averaging 25* Fahrenheit. BRRRRrrrr! Epoxy turns into molasses, and the pumps don't work. I built a "hot-box" with a 60watt light-bulb inside to keep everything warm at 85* Fahrenheit. I put foil-backed insulation on all the interior walls of the box, and a thermometer to monitor it all.
    85* is a good temp for it, because as I pull it out, and start working it onto the boat, it cools quickly. I have a couple heaters for the garage, and maintain temps around 50* while I'm working. When it's time to glass the bottom, I'm going to try to maintain at least 65*. Good thing Kerosene prices are dropping ! ! !
    A side note - the pads are 5.5" wide each, and 6' long starting at the back of the transom. I think a combined 11" of pad will be plenty !
ID:	313059Click image for larger version.
ID:	313058Click image for larger version.
ID:	313060Click image for larger version.
ID:	313061Click image for larger version.
  10. #55
    Great Stuff!!! Thanks for the update. Good work and very inovative! Gary
  11. #56
    South Carolina
    Great work. Yes, you can weld.
    Very nice. Enjoying reading and seeing your progress. One day, it will get wet!
    You cannot bring about prosperity by discouraging thrift. You cannot strengthen the weak by weakening the strong. You cannot help the wage earner by pulling down the wage payer. You cannot further the brotherhood of man by encouraging class hatred. You cannot help the poor by destroying the rich. You cannot keep out of trouble by spending more than you earn.
  12. #57
    Quote Originally Posted by home made tunnel View Post
    Very proud of you guy . You are a DO 'ER and posess some great skills . Your welding looks excellent and your creativity level is awesome !I'm a fabricator myself and can see that you have been inspired for years and are not afraid to get it done . Excellent work !!
  13. #58
    Jan 2010
    Venice, FL
    Keep it up. Boat looks good. Dig the trailer.
    Makes all the difference in the world. Imo ...
  14. #59
    sw florida
    Fantastic project. Great job.!!
    Dago
  15. #60
    Jan 2015
    Salt Lake
    Thanks for the update! You have clearly taken your time with this project, it looks fantastic! I have been both a mechanic and a welder at a local shop here in utah for the last 6 years and have been itching for a fun project. I have been researching homemade boats and your project has inspired me to now make a cat. Where did you come up with the basic dimentions? Keep the updates coming!
