Page 5 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 61 to 75 of 156
  1. #61
    Mar 2004
    Brooklyn Park, MN
    I use it because I hate to have to wash off the amine blush off the cured epoxy with water and then dry, then having to sand all before starting to put more epoxy resin and glass down. Below is a link to the peel ply. It just saves me the time of prepping the cured epoxy before adding more epoxy. The epoxy saturates the peel ply and the blush comes to the top of the peel ply once cured, then you pull the peel ply off and the blush comes off with the peel ply. Just like XstreamVking states.
    https://www.expresscomposites.com/pe...d-52008-srg-60
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  2. #62
    Jun 2018
    Floating around
    Very helpful thank you both
  3. #63
    Mar 2004
    Brooklyn Park, MN
    It's a damn shame to do this..... I will patch this wound soon
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. #64
    Oct 2017
    Hugo, MN
    But how are you gonna run your 3 15" subwoofers?
  5. Likes rjdubiel liked this post
  6. #65
    Jul 2012
    Lufkin, Texas
    A PO got the dash in my Vegas too. It also has about 60 small holes from what appears to have been a bimini top and other useless rigging abortions. At least I won't have to match flake!!!
    Josh Peterson
  7. #66
    Dec 2011
    Ludington michigan,on the shore
    At least you've got enough meat under the cut,so the dash won't crack through to the bottom.Give it a good fitting "PLUG" with a filler like Cabosil,Problem solved!!
  8. Likes nitro_rat, rjdubiel, TwzteD liked this post
  9. #67
    Nowthen, Minnesota
    My goodness, only started this in 2008!......
    Now I dont feel so bad. You been at this longer than I been at my Vulture. LoL Awesome to see it coming along again and cant wait to see it on the water, hopefully next to my big white turd. haha
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  10. Likes rjdubiel liked this post
  11. #68
    Mar 2004
    Brooklyn Park, MN
    Some progress, got both of the frozen steering cables out and made some outside transom braces that will connect the cap stringers to the transom.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. #69
    Oct 2017
    Hugo, MN
    Gonna be a sweet ride! Chic's gonna be all over you at the boat launch.
  13. #70
    Mar 2004
    Brooklyn Park, MN
    I wonder how the wife and kids will react to that!!!???
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. Likes Captaincj, Hippie459MN liked this post
  15. #71
    Mar 2004
    Brooklyn Park, MN
    Some progress
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. Likes tnelsmn liked this post
  17. #72
    Jun 2009
    Bristol, Connecticut
    Keep it goin !!
  18. #73
    Mar 2004
    Brooklyn Park, MN
    Thanks again for mixing for me Ken! Did some more after the kids went to bed.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  19. Likes tnelsmn liked this post
  20. #74
    I wish more people would start using foam, to replace stringers & floors. Its easier to use, lighter, never rots, improves resale value. And no, its not weaker. All stringers & transverse stringers, floors, transoms, etc., are "all" only as strong as the glass/resin that's used along with them.
  21. #75
    Jun 2018
    Floating around
    Makes sense but if the core is to be balsa which is likely to rot first, is this an issue?
