Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 46 to 60 of 156
  1. #46
    Mar 2004
    Brooklyn Park, MN
    Ok, I feel this may be the time to get some things done. There are 2 other Vkings being done, maybe I can add to the fun. Floor is in. My goodness, only started this in 2008!......
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  2. Likes nitro_rat, W2F a V-King liked this post
  3. #47
    Mar 2004
    Brooklyn Park, MN
    Thanks to Ken for stopping by to mix for me.
    Even got to hang a motor on the back before he left.Click image for larger version.
    Big
    HORSEPOWER!!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. Likes nitro_rat liked this post
  5. #48
    Dec 2011
    Ludington michigan,on the shore
    Getting started is the hardest part. Keep up the good work,You will be done in no time.
  6. Likes rjdubiel, RussF liked this post
  7. #49
    Jul 2012
    Lufkin, Texas
    I wish I could find the pictures of when I had twin 25hp Mercs on my Viper!
    Josh Peterson
  8. Likes rjdubiel, FMP liked this post
  9. #50
    Oct 2017
    Hugo, MN
    RJ, it's been a DECADE! Looks awesome though, will you be able to salvage all or most of the original gel?
  10. #51
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Captaincj View Post
    I will have to figure something out on the splashwell and some other repairs, but yes, will keep the original as its in good condition.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  11. #52
    That will be a great looking boat when done. Mine sat for a year, got a case of the git er duns and finished straight thru in a month.
  12. Likes rjdubiel liked this post
  13. #53
    Mar 2004
    Brooklyn Park, MN
    I don't think I will be able to do that in a month, but I got a case of that as well now. I do have a buddy on my case as I told him last spring it would be on the water in 2018........BUT IT WILL BE ON THE WATER IN 2019!
    FYI for anyone looking at doing this as well, here has been my resin consumption so far: 6 gallons (core and stringers 5 gallons - 1 gallon to set the floor and glass over the stringers). I am guessing another 2, maybe 3 gallons and that will be it.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #54
    Jun 2018
    Floating around
    Another winning thread, looking good sir, mighty good. This pealply stuff Im not 100% sure I grasp whats different about it? Is it easier to install or just easier to add another layer or whats the deal?
  15. #55
    Mar 2004
    Brooklyn Park, MN
    It's easy to lay over wet epoxy and helps me flatten the glass and filler. Then I pull it off the next day when the epoxy has cured and it's ready for more glass and/or resin. No sanding.
    Like on this application, I will leave it on and continue to work on other parts of the boat. It will be a cover and keep it clean, then when ready to glass over the floor I will pull it off and glass.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. Thanks LakeFever thanked for this post
  17. #56
    Minneapolis MN
    Great to see work getting done on this! Kinda cool how we can all motivate each other. I dig the color scheme, its almost the exact same as mine with the blue and silver reversed. They're truly a labor of love, my project was started in 2005, so don't feel bad about how long its been. With the floor in you're almost finished.
  18. Likes rjdubiel liked this post
  19. #57
    Jun 2018
    Floating around
    I gotcha now. So you have a layer of glass thats covered with some sort of parchment paper so you can work over it without getting soaked by your resin and you can peal it off after its cured? Sounds good to me, I am looking to make this process as easy as I can thanks for the explanation
  20. #58
    Lakefever.....That material is peel ply. It is a specialty product for this use. No sanding needed. Parchment paper will leave a nice smooth surface but will have to be sanded before being glassed over as it is too smooth.
    Jun 2018
    Floating around
    Good catch, my wording was quite poor in that last post ( lack of sleep ) but I do recognize the film/paper material is part of the peelply product of which I had read mention of in previous threads but wasn't sure until this one, what it is exactly. Its name sounds like peel and stick so I was cornfused a little. Is there any strength gains/losses to be had by using peelply over regular glass sheet?
  22. #60
    Peelply is a protective layer of perforated film normally used with a vacuum bag or resin injection system. It does work well as a protective layer and when removed, gives a textured surface to apply glass right over after cure with good adhesion. As far as making glass stronger, no.
