Results 1 to 9 of 9
Thread: Sea Star Steering Re-rig
06-18-2014, 07:27 AM #1Member
- Sep 2003
- 75
I'm redoing my sea star steering. I want to change out the stock fittings on the front of the cylinder to the -6 stuff. Whats a good source for the fittings and whats the best way to get the hoses through the deck? I'd like to do it myself just for the fun of it. Randy does some nice stuff on the Liberators, I'd like to make something similar.
06-18-2014, 08:52 AM #2
You can contact crankbearing also, he did an Hydrostream last week that looked awsome....
Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
06-18-2014, 09:04 AM #3
The Hoser on here. If you are using the Sea Star hoses and do not plan on changing them you need to stick with their fittings, -6 will not work!
What you can do is install a 1/4" inside thread bulkhead fitting use a staring Sea Star fitting inside the boat and a -6 outside, install you -6's on the ram and then get small hoses made to the ram with -6 on both ends.
06-18-2014, 09:18 AM #4
Sorry about my ignorance but........ what is a -6 ??
06-18-2014, 09:37 AM #5
heres mine.....
set mine up like tux said above....
i used bulkhead fittings from redhorse.....stainless brake lines to helm....and changed fittings on cylinder to "AN to NPT"Last edited by texasvector; 06-18-2014 at 10:33 AM.
06-18-2014, 10:04 AM #6Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
-6 is the industry standard for sizing. -6 = 3/8" inside diameter hose and the fittings that are applicable to that size hose.
06-18-2014, 11:28 AM #7Member
- Sep 2003
- 75
Hey TexasVector. That's exactly what I'm talking about. Do you have a parts list or something with the detail of each piece?
06-18-2014, 11:38 AM #8
what i used:
2 - "NPT to AN" fittings from hoses to bulkhead fittings under deck (i didnt use teleflex hoses....i had mine made to length and they "ended" with NPT not compression fittings)
2 - bulkhead fittings ( go through the deck)
2 -stainlesss 18" brake lines (all though you could have hydro lines made....the stainless corrodes a lil)
2 -"AN to NPT" fittings connecting brake lines and cylinders ( i cant remember what size -6AN to 3/8" NPT???)
i picked up all my parts from a local race shop but they can all be found online with google.
sounds like HOSER on the board is the man to go to for any hose needs.81' HYDROSTREAM VECTOR / slightly Modified 200
06-18-2014, 03:43 PM #9
Hoser on here has and will send you exactly what you need, no guess work!!
These are some I have done and all from Hoser.
These are done with all Eroequip hoses from Hoser.
