Results 1 to 9 of 9
Thread: Flo torque hubs
06-17-2014, 02:57 PM #1
Flo torque hubs
On a 280 Merc with a sporty, wondering if i can use the flo torque II hub or is it better to get the high performance hub. Thanks
T-BONE
T-bone
06-18-2014, 10:25 AM #2
fat shaft requires the one piece hub.
you'll need this one if you have a 15 spline prop shaft.
835257K 698 XR2001 Drag w/pro stock mota
06-18-2014, 10:50 AM #3
06-18-2014, 11:02 AM #4
personally i like the rbx123 by solas. fits tighter. cheaper and doesn't have the strips on it that fall off all the time.
06-28-2014, 12:00 AM #5Team Member
- Jul 2004
- Connecticut
- 6,011
- 465
- 168
- 912
- 951
Here is the Mercury Racing hub that is steel and for the 1.25" fatshaft. If you poke around you can get them new for $75.00. I believe that these get torqued to 55lbs.
06-28-2014, 12:06 AM #6Team Member
- Jul 2004
- Connecticut
- 6,011
- 465
- 168
- 912
- 951
06-28-2014, 07:48 AM #7
yes... direct replacement. the solas hub has the rubber fused to the steel portion of hub. no strips that fall
off and they stay tight.
they are around 140.00 ish for the kit.98 XR2001 Drag w/pro stock mota
06-28-2014, 02:49 PM #8
06-28-2014, 08:44 PM #9Team Member
- Jul 2004
- Connecticut
- 6,011
- 465
- 168
- 912
- 951
