Results 1 to 6 of 6
06-14-2014, 07:49 PM #1
Power trim and Tilt remote punp question
Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
06-16-2014, 12:18 PM #2
I think it's a reverse lock out solenoid but am not sure how it would affect using the pump for a jack plate.
Here is a thread that is related to it.
http://www.screamandfly.com/showthre...switch-missing
96 Cougar 23 MTR twin 300XS's. 100 something
98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
85 Baker RST 220 Laser SOLD
06-16-2014, 05:08 PM #3
I tried to activate the pump '' with and without '' and it didn't change anything...we will see with the load ( when the engine will be mounted up on the plate.
Thanks luv2gofastGlastron GT 150 W OMC 140
06-16-2014, 07:00 PM #4
Be sure to use the high pressure side, for the up function.If I remember right it's the smaller size fitting of the two.
06-17-2014, 04:17 PM #5
Thanks a million for the replies......
Now on another topic, there was a company that used to make a ''Wireless '' remote unit to control Power trim and Tilt for marine boats.
I am working on something that should work wonders, and not only it will control Power trim-and-Tilt but also the UP-or-DOWn of your hydraulic jackplate as well.
I received the components this thursday, finished the installation (wiring) during the week-end and the primary testings should be conducted within the next week or SO.
You WILL be able to remote (wirelessly) these items ( trim/tilt and Jack plate finctions ) with a simple thing. I promise.Glastron GT 150 W OMC 140
06-18-2014, 06:15 PM #6
Sounds like it may be ok for some,but I would be nervous flying 95+ in my Viking wireless, on a busy lake with a ton of stray signals roaming around.
