Results 1 to 9 of 9
Thread: Fuel line question
05-24-2014, 08:17 PM #15000 RPM
- Sep 2006
- Michigan
- 153
Fuel line question
Folks I have a fuel line question on the Mariner Super Magnum
Which of these lines is the return line? A or B
Thanks
05-25-2014, 05:55 AM #2
return line should has regulator on it
05-25-2014, 06:32 AM #3
Looks like a simple test if u have pressure guage turn pump on kinck a line off for a second if pressure spikes its a return line If It drops Its supply.
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
05-25-2014, 07:42 AM #45000 RPM
- Sep 2006
- Michigan
- 153
which of the two is the pressure regulator?
05-25-2014, 07:51 AM #5
similar laser setup
front line is feed........ back is return81' HYDROSTREAM VECTOR / slightly Modified 200
05-25-2014, 07:56 AM #65000 RPM
- Sep 2006
- Michigan
- 153
Thank you!
What is the difference between the laser and super magnum setup if they have similar fuel system?
05-25-2014, 07:59 AM #7
pic posted is a promax
05-25-2014, 08:09 AM #85000 RPM
- Sep 2006
- Michigan
- 153
Got ya. Guess my is the super magnum which has fuel system similar to the promax but a tad different.
05-25-2014, 11:27 AM #9Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Promax, Super Mag, and Laser EFI fishing motors are all the same intake as far as I know
Erik Kiser
