Results 1 to 15 of 16
Thread: sporty prop shaft?
05-09-2014, 09:07 AM #15000 RPM
- Aug 2006
- spartanburg S.C.
- 100
sporty prop shaft?
My sportmaster prop shaft (small shaft) broke, question is, can a cle or 200 lower unit prop shafts fit n the sporty?
05-09-2014, 10:16 AM #2
Only 1 1/4" shafts sportys tourqe master and a few later cle no fising shafts they are 1 3/16 there is a guy making a billet carrier on hete that will accept standard shafts you will then be able to run fishing shaft in a sporty with a rear drain
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
05-09-2014, 10:38 AM #3Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
you can run any shaft in it ,you just have to change the carrier which mean no drain and fill has to be done before its installed and thru the drive shaft bearings with water pump off or add a fill hole to sporty so its possible just a hassle
05-09-2014, 10:39 AM #45000 RPM
- Aug 2006
- spartanburg S.C.
- 100
I got a prop shaft but dont know if it came off cle or 200 merc, i also have a barrier carrier that the shaft fits but no oil drain plug n it, the shaft is real loose in my sporty carrier, didnt know if i might of stretched carrier when it broke? Tryn figure best way to fix, can u still get sporty prop shafts?
05-09-2014, 10:55 AM #5
I ran into this 2 years ago with a torquemaster, same shaft as the sporty. Converted to a fat shaft to keep the rear drain. After I had purchased the parts a vendor on this site began to build 1 1/4" small spline shafts. Do a search, can not remember who it was he may still build these. You could do what Texas said but would be a pain to change lube and also you would be running a 1 3/16" shaft. You already broke a 1 1/4" shaft so doubt the smaller one would last long.
05-09-2014, 11:58 AM #6
05-09-2014, 12:02 PM #7
You have a stock shaft (1 3/16). Soon you'll be able to buy a 200 carrier that will accept that shaft from this guy, and it will have a rear drain plug.
http://www.screamandfly.com/showthre...aring-carriersLiving in the Freedom provided by Bud Conner and his fellow warriors.
05-09-2014, 12:23 PM #88000 RPM
- Feb 2007
- lily lake WI
- 3,205
- 57
- 1560
- 342
The guy that was making the sporty's shafts is Scott Jordan from Jordan's marine very nice I think if there is a demand for them he would do another run
05-09-2014, 01:15 PM #919 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
88 xr2002
90 Stv pro comp
98 mirage 1/4master
05-09-2014, 03:21 PM #10
I think I must own the very last brand new in package factory Mercury small shaft sportmaster propshaft on the planet.
05-09-2014, 05:11 PM #11Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
shucks put it up for auction i bet it will go i have a couple of sporty small shafts but we all know how they look after the plating is worn off
05-09-2014, 05:20 PM #12
These are nice for prop selection but I had one on my sporty and a brand new big wheel is at the bottom of river ranch and I didn't even hit anything just sheared right off
05-09-2014, 05:33 PM #13
05-09-2014, 07:46 PM #145000 RPM
- Nov 2010
- orange tx
- 354
- 52
05-09-2014, 07:55 PM #15
