Results 1 to 13 of 13
Thread: Bob's coned lower unit or CLE??
04-03-2014, 08:46 AM #1
Looking for some thoughts and ideas for my 28' Checkmate with twin 200's. I'm currently running 24" of setback, 18" centers, Mercury DAH 26 pitch choppers with Bob's nose coned lower units. Prop shafts are about 1.5" below the bottom when running a straight edge directly in front of the gear cases. With current setup I'm consistantly seeing 69-72 mph. If I switch to CLE gear cases will I gain, stay the same, or lose speed. It would be nice to polish up some CLE's and slap them on and not deal with epoxy flaking off the Bob's units.....
J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
04-03-2014, 10:24 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
www.Sterndrive.cc Being very cost conscience(hmmm...clearing throat) & liking long warranties...you know, like the rest of us... You could buy two new aftermarket gearcases. Contact them regarding the lefty. They retail at $845.00 a piece, but dealers will treat you much better. I would entertain running them as-is, as a test, initially. After dropping your motors a hole or two, it will drop your rpm's about 400ish, if your prop pitch can deal with that(?). But bow lift is improved, etc. Ideally...two(2) brand-new Merc CLE housings would be great. Personally, I do not care for cones on a saltwater boat. My .02
04-03-2014, 01:20 PM #3
I have a CLE on my boat and love it. As you said, no worrying about aftermarket epoxy or paint peeling off. I suppose you could strip and polish one, but you'd be out there polishing every day to keep up with the oxidation from salt water. Up here though, hmmm ....
As for gaining speed, I've always found that the more setback one runs, the further up one can / has to go. That said, it sounds to me like you're running pretty conservative on height right now. How's your water pressure? Have you tried going up any further? As you already know, further up means less drag and (generally) higher speed.1992 Progression 22
Mercury Racing 250R
04-03-2014, 01:54 PM #4J-Town Hot Boat Team
Past Boats:
04-03-2014, 02:56 PM #5
04-03-2014, 05:24 PM #65000 RPM
- Apr 2004
- Blaine, TN
- 158
If you have to run a lot of Positive trim there is a Point where a Bobs cone is more Hydrodynamic (Whereas a CLE will have the Bullet pointed down) but other than that CLE Looks Cooler.. And I Like That
04-04-2014, 06:32 AM #7
i would run a cle, stronger internals
04-06-2014, 06:18 AM #8
04-06-2014, 08:09 AM #9
CLE's are no longer available from mercury. Will have to be sportys or used. Unless you are getting blowout I would stay with stock. Cones will slow you down unless you are running on the surface.
04-06-2014, 09:26 AM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
04-06-2014, 09:43 AM #11J-Town Hot Boat Team
Past Boats:
04-06-2014, 09:53 AM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
04-07-2014, 10:54 AM #13
