Results 1 to 15 of 21
03-16-2014, 07:05 PM #15000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
93 2.5l xri 200 loses water pressure when up on plane
Hey guys, Just looking for a bit of advise. I am likely going to buy a checkmate with a 200 horse xri on it. seller says he can idle the boat all day but when up on plane it loses water pressure, down to about 2psi and then it gets hot, buzzer comes on and temp goes to 200. It sounds like the gearcase had a nosecone put on it and some other shoddy work done and seller and I think that is likely the problem. He says he has had the complete waterpump kit replaced, tried head gaskets, and a few other things. My question is could it be any problem with the powerhead that would cause this?
thanks in advance.
03-16-2014, 08:56 PM #25000 RPM
- Apr 2009
- florida keys
- 719
If he put a new water pump housing on it's probably not sealing correctly. Off a plane it's under water with no air to suck in and when you plane off the mid empties and it sucks air and looses water psi.
Stan carson.
03-16-2014, 11:56 PM #3
or there are chunks of rubber stuck in the water tube from smoking a impeller ,some never account for those little rubber pieces then have a heat problem
03-17-2014, 05:16 AM #4
Is it too far up? Do you have a LWP?
03-17-2014, 06:04 AM #5
If it has a Bobs LWPU on the L/U, check the hose on the gear case...I've seen the hose have a rupture that was not easily seen and the engine would run good in the water at idle (hose is submerged) then overheat as soon as the boat came on plane (hose out of the water).... I would also look to make sure the water tube seal on the outlet of the waterpump is installed.
03-17-2014, 06:32 PM #65000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
Well i'd guess if its the hose that should be easy to find... how would a guy go about getting any rubber chunks out if that were the problem?
03-18-2014, 05:48 AM #7
The hose normally ruptures out, not in. I doubt rubber parts in the pickup are your problem. It's that once on plane the water pump sucks air not water.
03-18-2014, 06:12 AM #86000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
I had a friend with the same problem. He drilled the lower unit for the nose cone in the wrong spot. It would go on plane suck air and over heat. We build a new lower and drilled and tapped the hole in the correct place and never had the problem again
03-18-2014, 08:03 AM #95000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
That is what I'm hoping is the case, find a used gearcase and put on and be done. I have a buddy with a 2.4l 175hp merc, Thinking that I can borrow his gearcase and test it out to make sure that is the problem. From what I understand that 2.4/175horse gearcase should bolt right on, correct?
Thanks to all for the help.
03-18-2014, 08:47 AM #106000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Yeah the gear cases should interchange just fine. Try out his case that you know works and see what happens!! Good luck.
03-19-2014, 02:35 PM #115000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
I appreciate all the help and ideas from everyone, Thanks a million. I'm heading to pick this thing up this weekend. I will start by borrowing a gearcase and see if that solves the problem. If that takes care of it I have a line on a used cle for 800.00 complete. Questions on that: Is 800.00 a good price? and are the internals on the cle the same as a stock case? do props interchange? Thanks to everyone again
03-25-2014, 07:20 PM #125000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
Well, I got the boat home, now just wait for a foot of snow and a few feet of ice to melt so I can try it out. What do you guys think about a used 2 hole cle for 800.00? Guy is on the checkmate forum and says it has been taken apart and checked out, all in good shape.... Thanks again for all the input.
03-26-2014, 10:03 AM #13
The CLE prop shaft is the same as far as interchanging props with stock lower units (all but fatshaft lowers)....the inernals and not the sames as a stock lower, different bearing carrier, propshaft and gears (If I remember correctly). The two hole CLE is the first series and I think you need to make sure it has a blowout ring installed, they didn't have one from the factory.
03-28-2014, 10:13 AM #145000 RPM
- Apr 2009
- forest lake, mn
- 157
- 24
- 7
Thanks again for the help everyone, I will keep thread updated after I get it on the water. If anyone has any gearcases around for a 2.5 let me know what ya got, Thanks!
03-30-2014, 01:00 PM #15Junior Member
- Sep 2013
- Columbus, OH
- 21
