Page 9 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 121 to 135 of 380
  1. #121
    Im debating on if I should put small 3" stringers in where the foam boxes were at. Or leave it all open and "cleaner" looking.
    What yall think?
  2. #122
    Cleaning up the holes in the dash. The resin was the last bit in the jug and was a bit thick already.
    Attached Thumbnails Attached Thumbnails 20141014_170849.jpg   20141014_173843.jpg
  3. #123
    Mar 2004
    Brooklyn Park, MN
    here is the side stringer on my 1978 vking. this is original.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. #124
    Hmmm.......did yours have flotation boxes in the sides like mine?
  5. #125
    Mar 2004
    Brooklyn Park, MN
    No. That was a rule later per coast guard I think. Just like u see was original. Foam under deck in the bow and some was up under the splashwell.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  6. #126
    Ordered 1 more gallon of vinlester 700 from US Composites a couple weeks ago and yesterday opened it up and used some of it on the transome and it was much thinner than the stuff that came in 5 gallon buckets. And the temperature was 10-15* cooler also. But it sure did wet out much easier.
    This is the 13th gallon of resin on this rebuild . fyi
  7. #127
    Got all the paint and primer. 2 gallons of clear Duraflint ll and 1 gallon of black primer for base coat clear coat and the pearl pigment to add to the clear.
    I have a gallon of un opened Dupont Epoxy primer that I wont need if anyone wants it. $50
  8. #128
    Ok. Now who drilled these hole in my bow and had a pedestal fishing seat on my Stream?
  9. #129
    Nowthen, Minnesota
    That reminds me of a vking I seen a while back for sale and someone had put a hole in the deck and put a pedestal seat for fishing but dont know what ever happened to it. Maybe someone bought it and fixed the hole then sold it to you.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  10. #130
    This boat was registered to someone in Wright City Missouri between 99 - 2003 then a guy got it and let it sit in his shed till a DWI came along and needed money. And I seen it the 2ed day he set it out along the road. And picked it up for $200
  11. #131
    Worked on the Stream a bit today. Layed some balsa core up in the bow
  12. #132
    Sprayed a bit of primer on the rear deck. Trying to get some of the tiny dips and imperfections to smooth out. Just some very small stuff that I notice that no one else probably wont see. BUT I DO! So primer on sand off primer on sand off.
  13. #133
    Jan 2009
    Lafitte, Louisiana/ Beaumont, Texas
    Roadkill are you block sanding or what to get that flat and smooth? Just getting ideas on what I need to do to my viper.
    Modded Hydrostream Vking
    Hydrostream Vking
    Hydrostream Viper
    Sold, Hydrostream Vector, Allison xb2002
  14. #134
    First after the balsa I used a strait.air sander then a DA with 40 grit but it sanded all diffrent rated due to the diffrent hardnesses of the balsa. Thus the filler and all the sanding. This final sanding spree is being done with a 9" flat hand sander.
  15. #135
    Jan 2009
    Gotcha thanks for the input and ill be keeping an eye on this thread also. Its a learning curve for me
    Hydrostream Vking
    Hydrostream Viper
