Results 106 to 120 of 380
07-28-2014, 10:17 AM #106
I am back filling with resin but its so hard that the areas where resin and balsa are side by side they wont sand sown evenly together. Just wondering if I use bondo to fill in the low spots then shape it all then a final layer of ester and mat would be good or will the bondo crack and make cracks thru the mat and paint once finished. The way it is rite now I 275#s can sit on the deck and it not creek or flex too much. And will be a lot stiffer after the top layer of glass.
07-28-2014, 10:24 AM #107Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Resin mixed with q-cell will sand easy. Use a grinder to cut down the hard resin hi spots you have, and then use the q-cell to fair out. Leave it a little low for the glass to fill last 1/8'' or so. Fair with a good vinyl filler and prime.
08-04-2014, 09:50 PM #108
Finally glassed the rear deck. Hope it turns out good when looking at it painted
08-05-2014, 08:44 PM #109
08-16-2014, 10:28 PM #110
Worked on filling in the dash holes with plywood and glued em in with resin. Sloppy lookn now but oh well
10-04-2014, 11:55 PM #111
While I was removing the floatation from the boat I started debating if I should cut this inner part of the drop down skirt off flush with the top part of the upper cap. It would make the removal of the floatation box much easier. But dont want to be gone and wish it was there once I get the seats in... what do you think?
10-05-2014, 07:32 AM #112
Vectors don`t have it so why should the Viking? My only thought on why it`s there would be the length of the boat. Did they do this for support or styling? I think i would find a Vector and measure from the dash to the back seat support then compare with your Viking before cutting.
DB
10-05-2014, 09:11 AM #113
My Vulture doesnt have them either and I see no evidence of them being cut out of mine and the Vulture is like 2 feet longer (20 foot) then the VKing.
-Kevin
1982 Hydrostream Vector
1982 Hydrostream Vamp
1973 Hydrostream Vixen
10-05-2014, 01:42 PM #114
Its not att hed to the floor at all and dont have any wood structure behind it. Wonder if its there for your knee to lean up against?
10-06-2014, 07:42 PM #115
On the comp models, they are bolted to the stringer with two quarter inch bolts,it keeps top deck from flexing in rough water and cracking in the corner of the dash.
10-06-2014, 09:33 PM #116
The ones in my vking are attached to the side flotation stringer deal with 3 screws in each.
There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
Quinten
86' Hydrostream Vking YT, 2.4 Bridgeport EFI
(Rigging and interior in the works)
88' Hydrostream Voyager, 2.4 200 Merc
Boat of The Month Feb. 2009
resto here, http://forums.screamandfly.com/forum...d.php?t=144414
Dedicated to you Dad, I miss you! 1935-2008
10-07-2014, 04:59 AM #117Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
I like them being in mine. Give a little more style to the interior. Def help to support the deck. I added some foam core to mine to make them stiffer.
10-09-2014, 09:02 PM #118
Spent the day cutting out the floatation boxes. And sprayed primer on the rear deck to get a better view of where to shape it a bit more. Sure does make the high and low spots show up better being all the same color now
10-11-2014, 11:42 AM #119Junior Member
- Sep 2009
- Trinity,Florida
- 21
That's NICE! Looks like a Bat Boat I would do the same for a Venus if I find one to recore! Nice pics been following this tread, Thanks for the inspiration!
10-12-2014, 02:58 PM #120
Im debating on if I should put small 3" stringers in where the foam boxes were at. Or leave it all open and "cleaner" looking.
What yall think?
