Page 2 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 16 to 30 of 380
    Quote Originally Posted by roadkill636 View Post
    Do y'all think I should go ahead and remove all of the flotation on the bottom outter part of the hull?
    Keep up the Awesome work.....And my 02 is get rid of Flotation box's...Chances are they are wet anyways......You will find that out once your into them...Its a job that takes time.....But well worth it in the end!...Thanks for sharing your build....
  2. #17
    Aug 2012
    beaumont, tx
    Yes from me... When you pull the foam boxes from the sides, just make a 3'' stringer where the inner lower part of the foam box was.
    helps a lil with storage too
  3. #18
    Has anyone raised the transom a couple inches while doing a splashwell delete? Im wanting to raise the whole splashwell area 2" - 3" and have the flat deck . I think it mite look pretty good instead of having a jack plate cranked up so much.
    Thoughts ???????
  4. #19
    Sep 2008
    Down The Bayou And In The Sticks, La.
    That doesn't sound like a bad idea since my jack plate is all the way up and could use a lil more height. And my need to with all the weight of the gas and motor...
    Wilson
  5. #20
    Jul 2012
    wareham MA
    Thoughts ???????
    I built mine up a little higher and ive seen another build on a viper on here that raised his up quite a bit. Everyone thinks the same thing about the extra height. It will have less water rushing over the top that way also.
    link to proprider's mod http://www.screamandfly.com/showthre...viper+restomod
  6. #21
    Im wanting to raise the transom AND the rear deck up 3" or so and have the rear dec k flush with the top of the transom. And maybee even sculpting in some Pipkorn convex concave into it.
  7. #22
    With the rear of the transom fiberglass already hacked off when I bought it I deceided to go ahead and remove the whole thing inside and out to make the new stringers able to tie into the transom with big knee braces.
  8. #23
    Im concedering mounting the fuel tank like this. 9" up off the floor. It will give plenty of room for the batery and knees. But I wonder how much the elevated weight will affect control
  9. #24
    Jul 2012
    wareham MA
    personally, I think I would rather move fuel forward, than moving it up that high.. but I like the idea of higher transom/rear deck.... as far as the pipkorn concave stuff, it sounds good... got anything for a visual?
  10. #25
    Started today off with removing some of the core from the rear of the pad.
    with the transom completly gone it was real easy to get to.
  11. #26
    This is what the 1/2" balsa looked like from the pad.... saturated with water
    Attached Thumbnails Attached Thumbnails 20140301_122341.jpg   20140301_122231.jpg
  12. #27
    Here's what I ended up with at the end of the day. Finished and before pics
    A nice clean Hydrostream bung hole . The two pieces of plywood surrounding the drain hole looked very well sealed and strong but I ground them out anyway for added security.
    Attached Thumbnails Attached Thumbnails 20140301_153040.jpg   20140228_203122.jpg
  13. #28
    Instead of forkn over $100 for a sheet of "marine " plywood dad gave me one of these 3/4" sheets. I sanded off the black paint and discovered no fillers or knots. Just a couple of small nail holes that I epoxied shut and best of all its 12 ply!
    Attached Thumbnails Attached Thumbnails 20140301_144900.jpg   20140301_144950.jpg   20140301_145109.jpg
  14. #29
    Do you think 4" will be a good amount to raise the transom?
  15. #30
    Dec 2001
    Sunbury, Pa
    When mounting the gas tank keep in mind where you are going to mount the fill and vent. You will need that area higher than the tank. I ran into that problem on my daughters boat since it is a low sitting boat. If you mount the tank high like you are showing in the picture your vent will be spitting gas all over the boat when the sun come out
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
