Page 10 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 136 to 150 of 380
  1. #136
    Quote Originally Posted by Deznuts3570 View Post
    Its a learning curve for me
    me too... I aint never messed with fiberglass before. Or restored a boat.
  2. #137
    Anyone wanting a concave contoured rear deck better start getting use to this
  3. #138
    Sep 2014
    Rockport Texas
    Cant wait to see the finished outcome. Looks great. Re-doing mine so all the pics are helping. If you don't mind me asking why didn't you rip out all the fiberglass going up to the side walls.
  4. #139
    Not sure what your refering to "sidewalls" what post# picture are you looking at?
  5. #140
    Got the Viking flipped over and up in the air today to make it easier to work on the bottom of the hull and on the inside top of the rear deck. Because none of the costom rear deck is glassed onto from the INSIDE of the boat yet. Setting like this upside down it is tremendously easier to get to and lay lay down some glass and resin.
    Attached Thumbnails Attached Thumbnails 20150228_204039.jpg   20150228_204103.jpg   1425182205964.jpg
  6. #141
    After getting the transom all done and bottom sanded down shot a coat of black primer on it today.
    Attached Thumbnails Attached Thumbnails 20150508_154759.jpg   20150508_154812.jpg   20150508_154919.jpg
  7. #142
    Shot some paint on it saterday and last nite. Poor conditions for panting but oh well.. its what i got. Some fine sanding then a couple coats of clear will make it better.
    Attached Thumbnails Attached Thumbnails 20150512_175645.jpg   20150511_220459.jpg   20150511_223342.jpg   20150511_223323.jpg   20150512_175020.jpg
  8. #143
    Apr 2015
    Baltimore maryland
    wow what color? looks like copper. its different but I like it.
  9. #144
    Aug 2012
    beaumont, tx
    That's awesome! Dare to be different! !!! Looks great
  10. #145
    Jul 2009
    savannah,ga.
    Lookin' good! Can't wait to see it with the clear.
  11. #146
    The paint is clear but i mixed in some COPPERHEAD FIRE chameleon pearl. The whole thing is all one mix but it changes color with the diffrent angle ya look at it.i aint. Ever sprayed a boat before so this is a learning curve for me. Up close shows it too.. i need to learn to buff in the near future.
  12. #147
    Looking for openions on where to glass in a flat spot to mount a Hot Foot? I left out the flat bulkhead under the bow. Right side steering. If i mount it on the right side it will be way up the side of the hull and seems it will be uncomfortable with leg being almost ztrait out. Wondering about mounting it dead center in the very bottom of the V so left foot would be for the Hot Foot? The leg would then be bent down at a much better angle.
    Thoughts??
  13. #148
    Mar 2004
    Brooklyn Park, MN
    I have seen left foot operations on the hot foot, but that would be weird for me. Sounds like your going with right side steering, I would angle the seat a little to the left and put it where it is comfy. They are not too bad once your in there driving on the right side, but need to make sure its right for you first.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #149
    Apr 2013
    Lexington, ky
    I put my hot foot on the left, outside of the console area. I have no regrets, if I had a right leg I just don't see where you could be comfortable with the limited amount of room under this old 1977 dash. SSTom drove my boat a couple times and said after a minute of using it was almost as natural as using his right foot. Haven't had anyone trip over it or anything to complain about.
    Slimm
Name:	Left side Hot Foot.jpg
  15. #150
    Went ahead and glassed in a piece of 12 ply 3/4" plywood on the right side. And rolled gelcoat on the floor and sides and all under the bow. I rolled it on with a regular paint roller first then for the 2ed coat i used a very corse roller to make a bit of texture on the floor for traction when wet. The small amount of brown pigment from US Composites sure does go far. After rolling it on im happy with the way the texture came out.
    Attached Thumbnails Attached Thumbnails 20150601_185912.jpg   20150601_185521.jpg   20150601_180801.jpg   20150601_180746.jpg
