Results 13,951 to 13,965 of 18756
03-31-2021, 10:01 AM #139517000 RPM
- Dec 2002
- South Florida
- 2,296
- 154
- 541
- 11 Post(s)
I assume you meant 12cm thick. That would be about an inch thicker than a standard slab over here. When you install your machines you get the benefit of the thicker slab. I have a few friends who have installed car lifts in their garages. A 4 inch slab just doesn't work. My own garage floor cracked diagonally shortly after we moved in. Just not thick enough.
03-31-2021, 01:25 PM #13952Screaming And Flying!
- Jun 2012
- England
- 10,973
- 10
- 415
- 2176
- 5 Post(s)
There was already a substantial base in place. To level it correctly there were depths of 8” of concrete poured . Reinforcing rod was also used —— this is one of the reasons they ran out of materials. I inspected it today. Floor covering arrived later in the day. Easter weekend, so not much activity. Going to be hard pushed to get all done and dusted before all the machines come in on the 12 April.
Another couple of days and my workshop is cleared and locked down tight ready for moving.
03-31-2021, 01:59 PM #139537000 RPM
- Dec 2002
- South Florida
- 2,296
- 154
- 541
- 11 Post(s)
Sounds like they did it right to me. Before my career in the Fire Service I worked in construction so I have some knowledge in that area. Probably why I have never been satisfied with my own house was built. Have spent the last 30 years trying to correct some of the deficiencies.
03-31-2021, 02:44 PM #13954The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...for a guy like you jackie, placement of each machine is next of importance, for the electrician to place outlets & lights, etc., exactly where you need them. not to mention a few extra here & there, just for the hell of it. draw those placements out on a pad of paper for the guy. you know the routine, hell, like you have'nt done THIS before, right?...
03-31-2021, 03:09 PM #139555000 RPM
- Apr 2006
- United Kingdom
- 223
- 10
- 20
- 43
03-31-2021, 04:07 PM #13956Screaming And Flying!
- Jun 2012
- England
- 10,973
- 10
- 415
- 2176
- 5 Post(s)
my old workshop had four, LED, four foot lights in the ceiling. Plus one above the work bench.
Was reasonable , adequate, but that was it. I am sold on LED strip lights . New shop can have up to six installed . Lathe has to have its own light. Pillar drill should have had, but didn’t. I have more than enough lights to suffice . I bought a pack of ten ,
03-31-2021, 07:47 PM #13957The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...led lights are great. they use next to no power, so you can install three times as many and still not use near the amount of juice you used to...
04-01-2021, 09:00 AM #139586000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
LEDs Changed Everything
LEDs have changed the game in lighting. Yes, they are cheaper to burn but the foremost advantage in shop lighting is the "instant on" in cold temperatures. Another advantage is in dealing with fluorescents was the broken tubes, mercury, flickering and humming. I have a box full of T12 ballasts I can't even give away? Global production of T12 bulbs stopped 10 years ago. I re-rigged my shop for T8s thinking that they would be the long term solution. I was wrong. LED development was an explosion. I just replaced my corded work light with a cordless one that charges via 12V USB cord. No more broken bulbs or rough duty bulbs. CFLs are becoming scarce in the hardware stores too. I don't think there are any vehicles produced today that still use 12VDC incandescents?
04-01-2021, 09:13 AM #13959The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...and for air-conditioned space, like we all have here in florida, the a-c is no longer fighting the heat that the old fixtures used to put out...
Lake X Kid liked this post
04-01-2021, 03:56 PM #13960
Tom Stickle .....
Spoke with Tom today. He is still in the hospital (rehab), as they continue to work on his leg infection. Said he is not making much progress. He'd like to go home but knows they won't let him out until it's under control.. I think a phone call from a few of you would go a long way towards lifting his spirits. He runs short of breath when he talks on the phone, so he won't be able to talk long (he'll let you know). I don't think I should post his number here, but if you would like to call him, send me a PM and I'll send you his cell number.
OLEGATOR, GENE LANHAM thanked for this post
04-01-2021, 03:59 PM #139618000 RPM
- Oct 2011
- Southern California
- 3,514
- 177
- 449
- 3381
- 2278
- 29 Post(s)
Negotiating a major sponsorship for a race boat, must have taken some skill and/or determination.
“How many spectators at a boat race,” asks potential corporate sponsor. (Please Don't ask about television and major media outlet coverage).
When it comes to tunnel circuit racing, I think the Europeans were ahead of the Yanks. The Americans in the early 1970’s seemed to be satisfied with a local sponsor (if they had that). Cees, Bob and Tom were flying corporate colors, when other competitors were deciding what their favorite color was to put on their race boats. (Correct me, if my recollections or observations are wrong).
Maybe the Merc and OMC rivalry benefitted many drivers, and made them complacent in pursuing sponsorship money. Therefore, more kudos to the early pioneers who brought big name sponsors to tunnel boat racing.
Bill Seebold was a hometown guy from the Busch neighborhood, that geographically benefited Bill and his family. (And Bernie Little had Bud distributorships that helped cement his connection to the Busch family). If Bill writes his book, I hope he has a chapter, about acquiring major sponsorship in cold-calling exec’s offices. And having seat down meetings with them, and presenting his racing portfolio.
But the negotiating I would like to have been a witness to would be. Not Tom’s and Bob’s, but Cees. Tom and Bob seemed to me be more polished, than Cees, who was more apt to tell you want he thought. To be present when Cees van der Veldon pitched for major sponsorship, would to me be an interesting session.
And opposite of Cees outgoing demeanor, would be Renato Molinari more reserved social attitude. Someone like me wonders how did Renato approach Martini & Rossi. Was he alone, or did he have a representative talk to the appropriate corporate connections. And then there is Jackie's approach to said sponsorship.
04-01-2021, 04:08 PM #139628000 RPM
- Oct 2011
- 3,514
- 177
- 449
- 3381
- 2278
- 29 Post(s)
04-01-2021, 04:12 PM #13963Screaming And Flying!
- Jun 2012
- England
- 10,973
- 10
- 415
- 2176
- 5 Post(s)
ROY, this is going to take a lot longer than i have time for right now.
PARKINSON WAS THE RINGMASTER OF SPONSORSHIP.
CANON—-JOHN PLAYERS——Parky brought them all to the table . —- GG AND MERCURY decided who the drivers would be. RENATO did have a number of influential backers who brought in Martini- but we are opening a new book here—- not just a chapter —- i am tired and i am going to bed .
04-01-2021, 04:17 PM #13964Screaming And Flying!
- Jun 2012
- England
- 10,973
- 10
- 415
- 2176
- 5 Post(s)
04-01-2021, 04:28 PM #13965The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...tom got a staph infection in his leg, or? they gave me one during a simple miniscus knee operation. called mersa. methisilin resistant staph. bad bad bad.
