Results 31 to 37 of 37
Thread: Opti rebuild
12-02-2019, 09:02 PM #31Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
12-02-2019, 11:12 PM #32Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
Same as carb.... The opti goes popty......because lean out.......injectors.....maybe #6 as lowest gets the trash........I don't know.........move along theres nothing to see here.......stormtrooper.....
Dave_r liked this post
12-03-2019, 01:21 PM #33Member
- Feb 2016
- modesto ca
- 47
- 11
- 41
Our rev limiter is @ 8500 regardless if it's in break in mode or not. Our first year with this motor we broke a piston skirt at about 45 hr. And then we find out you need to replace them every 40 hr. We seen no sign of over oiling. Maybe the opti becomes a hole new engine @8500 rpms. So maybe I'm in the wrong thread. Is there a opti racing thread?
12-04-2019, 11:08 PM #34Member
- Dec 2006
- Central Wisconsin
- 81
- 7
Failure on number 6 is often a cold seize. 6 is the first cylinder to get the cold cooling water and if you get a thermostat hung open bad things happen.
12-05-2019, 08:45 AM #355000 RPM
- Mar 2009
- Seymour, Tn
- 176
Optis do not limit power when they are in break in. The only limitation would be from the extra oil causing it to run rich. The DFI oil will make it last longer than the Premium Plus.
12-05-2019, 10:49 AM #36Member
- Feb 2016
- modesto ca
- 47
- 11
- 41
Correct me if I'm wrong. I don't see how it can run rich when the oil never mixes with the gas.
12-05-2019, 11:03 AM #375000 RPM
- Mar 2009
- Seymour, Tn
- 176
It doesen't. But the crankcase compression pushes it through the transfer ports. That's why they smoke more and carbon the plugs during break in. I don't think it would effect performance much if at all.
