Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 60 of 60
  1. #46
    Sep 2004
    Illinois
    Quote Originally Posted by rossi View Post
    I didn't realize you were from MD. Romp would understandably be to far of a ride !
    MD is too far???
    Quote Originally Posted by Image 21 View Post
    Little update , been trying to remove core, what a nightmare , rotten, then rock solid then dry , about 50% is actually bad, but going till I hit 100% dry which is at the dash, or 6-8" before it. Splash well is back in and have to put one layer of glass on it and its done . will get up some pics when I makes some decent progress
    When I was removing the core in mine I ran into the same situation around the driver/passenger footwell area....good, virgin, well-bonded core outside of the floor register. Below the floor though was a complete trainwreck. Once I cut a few test areas around the floor register, within 12hrs water began seeping through the inner laminate in the pad area....so it was really really wet.
    I almost didn't cut out the bulkhead and check the bow...but I'm damn sure glad I did because this is what I found.
    I don't know how mine ended up with good core aft of the footwell bulkhead, and completely rotten forward, but after I cut out the airbox and inner skin on both sides, I removed the entire bow core with a 4" putty knife and a shopvac.
    1976 Hydrostream Viper - 2.5 EFI
    Resto Thread Here
    2010 Go-Pro Stuff
    "The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
  2. Likes Laseraddict liked this post
  3. #47
    Jun 2004
    Lakeridge NY
    I've never seen so many of basically the same boats built so many different ways. I don't think I've ever seen two Streams that build wise looked the same !
    (Apricot)
    Hydrostream Ventura II/Merc
    (sold)
    (Bruiser Scheme)
    Hydrostream Viking/Merc
    (sold)
    (tri color letdown scheme)
    Hydrostream Valero/Merc
  4. Likes Laseraddict liked this post
  5. #48
    Jun 2008
    Annapolis Md
    Quote Originally Posted by cutwater View Post
    Nice work, Donnie. Get-er-done and bring her up to the Romp
    That's my plan Kent.
    1983 shadow 1997 3litre mad efi SOLD
  6. #49
    Jun 2008
    Annapolis Md
    My stream now is totally opposite of the last one, when the core is removed normally the bottom is kinda flexible, this one is rather solid. Took me a hour to do a 12"x14" section, going to be a long spring.
  7. #50
    Jun 2008
    Annapolis Md
ID:	294262Click image for larger version.
ID:	294263 Man wet or kinda rotten, 4 hrs and I'm to dry core on side one.
  8. #51
    Jun 2008
    Annapolis Md
    OK so have the pad cleaned out and started grinding out all the old glass from the old floors and all the extra mess, found carpet and tape under 3/8" of glass , looks like a lot of grinding to go .
  9. #52
    Jun 2008
    Annapolis Md
ID:	296237Not much progress, busy time at work, did some clean up grinding, got my balsa in couple days ago and have the stringers cut just have to keep grinding away for the new
  10. #53
    Jun 2008
    Annapolis Md
ID:	296301Certainly cuts down on grinding when it comes out in sections like this
  11. #54
    Sep 2004
    Illinois
    Just curious...where did that chunk live??? Under the floor register I assume?
    Resto Thread Here
    2010 Go-Pro Stuff
  12. #55
    Jun 2008
    Annapolis Md
    It was in the corner by the foam box in the stern, was under the floor , and core , was the use one floor in the boat , didn't take much to pull it out.
  13. #56
    Jun 2008
    Annapolis Md
    So with the rain I was able to work on my rig , got some balsa in tonight, put a layer of two ounce matt down first , then corebond , then some heavily wetted balsa core , will get a pic up tomorrow before I start glassing it in
  14. #57
    Jun 2008
    Annapolis Md
ID:	297277One side done , and yes I recore my boats in a odd way, I do one side at a time so I have a work platform. And don't distort the bottom , I have it craddled but still don't like walk on it with no core .so core has a layer of 2oz over it
  15. Likes Laseraddict liked this post
  16. #58
    Jun 2008
    Annapolis Md
    Well I'm still working on her , been busy will get some updates soon
  17. #59
    Jun 2008
    Annapolis Md
    Well few years later this boat is back in my garage, after selling due to a divorce, moving 4 times I’m Right where I left off. Soon I get her set up in the shop again we will continue this saga of madness.
  18. Likes LakeFever, tnelsmn liked this post
  19. #60
    Jun 2008
    Annapolis Md
    Picked up a deal on two motors. Only need one but couldn’t turn it down. Click image for larger version.
ID:	484229Click image for larger version.
  20. Likes Laseraddict liked this post
