Results 16 to 30 of 65
Thread: horned 200 block
01-26-2014, 08:01 PM #16
I'm working on a super gas promax now. Leaving the xri on and adding the horn to the front.
XR2001 & XB2002
01-26-2014, 09:17 PM #17
im talking about changing the front half to crank case injected front just like a 260 pretty much it would be a 260 except the block 200 porting
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
01-26-2014, 09:22 PM #18
i do realize the 200 block could be ported like a 260 but im thinking cheap here because not looking for every hp left in just think put the front on a ole fishing motor and go if she blows so be it
01-26-2014, 09:30 PM #19
01-26-2014, 10:01 PM #20
01-26-2014, 10:04 PM #21
01-26-2014, 10:05 PM #22Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
Danny the 96/99 200 sleeve in an advance sleeve is the same sleeve number as the 225 pmax, the block just does not have rod slots and bottom on the exhaust cavity is not opened up so the horn may be a great deal but i bet not that much, i got a digital horn left off my 280 when it was a SVS and some other stuff so im not into building any more hot rods but who knows i have amnesia regular these days
01-26-2014, 10:17 PM #23
yeah i was thinking looking for 96-99 block
01-26-2014, 11:19 PM #24Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
Tommy behave
01-27-2014, 02:11 AM #25
01-27-2014, 07:41 AM #26
Advanced Sleeve makes a sleeve for a 2.5 fishing motor that has drag port timing.
They call it XRI Drag - part # 1094SAdeath is certain; life is not
texasvector, wanagofass liked this post
01-27-2014, 10:44 AM #27
cheap
01-27-2014, 10:51 AM #28
- Hydrostream V-King with a Drag - SOLD
- STV RR Drag with a Drag- SOLD
- 18' seacraft c/c 200 merc- SOLD
- 18' Action Marine Retired & "Wet"
- STV Needle Nose " The Heat" - SOLD
- 21' Triad- "The Sipper"- SOLD
- 26' concept c/c twin 200 Mariners -SOLD
- STV RR - "Lil Sista" on a Strongback Trailer
- 18' Action Marine on a Strongback Trailer
Everybody wants a piece of the pie, till they try it!!!
01-27-2014, 11:14 AM #29
Not everyone is gonna N rig it like you did, I told you when i saw that linkage you where playing with disaster but you can;t fix dumb plain and simple just can;t do it. Takes time to do stuff rt. One of these motors will run okay with the horn but you will want the big front on it and if nothing else open the block up on the bottom to let the charge out maybe while it is apart take 10 mins to clean up the rod slots in the stock block other than that it might run good, should be better than the stock laser front on it that and either a a 48 or a63 box leaned way down should run fine. Would not run the stock promax or 200ecu on it period not with that much more air coming in. Dez nuts
01-27-2014, 11:39 AM #30
