Results 1 to 7 of 7
    May 2002
    east texas
    ?? fitting on side of 2.5 260 horn w/hose to regulator
    Have my engine apart for rebuild. Today I found that the "barb fitting" on the side of 2.5 260 horn w/hose that goes to regulator was plugged with some kind of gunk ? What kind of issues will this cause ?
    rick
    North Branch & Pine City, Mn.
    It will not give you correct fuel pressure. That is the vacuum reference.
    The Reverend, (Cedar Machine Service on Facebook)
    1989 HST 2.5 260 Merc Offshore
    1991 Vaserette YT 200 Mercury
    1988 Venus XT 200 Yamaha
    1983 Viper II Merc 90
    1977 Viper
    Mini GT tunnel, 25 Merc
    "African Queen" pontoon 25 Merc
    Aluma fishin tub, 20 motors to choose from!
    GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
    shreveport,la
    Only thing it will do is not lower the pressure at idle. Won't hurt anything and won't affect fuel pressure at anything but idle
    Erik Kiser
    Sep 2002
    Yep... The vacuum pull from the plenum at closed-throttle idle tells the regulator to lower the fuel pressure for an appropriate fuel-air mix at idle.
    May 2002
    east texas
    Thanks
    rick
    Gothenburg, Sweden
    It is a nice little hack due to the operating range of the injectors.
    Chances are the MAP sensor fitting found near the starboard front corner of the plenum is also clogged and is the usual culprit and will cause all types of running / driveability problems . If your boat sits for more than a couple of weeks it should be cleaned . I carry all the stuff to clean it with me in the boat tool bag ..
