Page 2 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 16 to 30 of 225
    May 2005
    Greenville, NC
    Nice work Jeff. Wanna build ma one for a Looper?
    Ló fasz racing
    Joe Horvath
  2. #17
    May 2001
    New Hill, NC
    That 40 amp flywheel will make a huge improvement on your holeshot! Keeping your 40 amp charging system lets you have the best of both worlds!
    Looks good, Jeff!
    Tony Brucato
    (919) 718-0249
  3. #18
    Aug 2004
    CONWAY SC
    Quote Originally Posted by dez nuts View Post
    We should have a 40 amp flywheel here shortly for a buddys promax i am doing, They look very nice i beleive if they work rt he will be very busy building these for everyone with a 40amp or 16amp mercury the 40 amp weighs the same as a stock mercury alum flywheel and the magnets won;t break who wouldn;t want 40 amp changeing and not gain weight it;s a no brainer unless you only use the boat for all out racing. Look forward to seeing them and testing one here next week too. Dez nuts
    Shipping out tomorrow, should get by friday. Jeff
  4. #19
    Dec 2011
    Ottawa
    Any advantage over the factory merc Bridgeport 16 amp ?
  5. #20
    Feb 2005
    Sebastion Fl
    Quote Originally Posted by jeff dunn View Post
    Thanks jeff hope to be ordering many more from you here shortly, Dez Nuts
  6. #21
    Aug 2004
    CONWAY SC
    Few pounds lighter, and magnets don't crack or come loose. Jeff
  7. #22
    Aug 2004
    CONWAY SC
    Dave sent out today, look for it fri. Jeff
  8. #23
    Aug 2004
    CONWAY SC
    Fast Eddy's new 16 amp flywheel. Hope it works well on your Stv.
  9. #24
    SE MN
    What electrics do you need to change on the motor going from 16 to 40 amp?
  10. #25
    Aug 2010
    N.Florida
    Quote Originally Posted by jphii View Post
    That's what I was thinking!
  11. #26
    Aug 2004
    CONWAY SC
    You will need a 40amp stator, and the 2 voltage regulators that go with it. Same power packs and coils, but they will be mounted in new location from old. Jeff
  12. #27
    Feb 2005
    Sebastion Fl
    Quote Originally Posted by Varmint View Post
    Lighter and also give you a 40 amp charging system that keeps your battery charged at all times a must if you run a bib pump in the boat and do long runs or a sterio or anything else that draws juice, it;s a win win on a river running boat have the best of both worlds good charging and still lite flywheel on your crank i think for anyone that is just straight out racing the stock is fine or go with the lighter balanced flywheels that are out there or one of jeffs new 16 amp flywheels there are alot of good flywheels out there now, but this 40 amp deal is something i have been looking for for awhile, Think it;s gonna be a big seller for you jeff. DEz Nuts
  13. #28
    Feb 2005
    Sebastion Fl
    Jeff you might want to fabracate up the alum plate that the pro max use;s on your cnc and sell them with the 40 amp flywheel at a small charge so people have what they need for the retrofit, Maybe even stock the stators and regulators and sell as a package to the guys that need everything for the change over just a idea but the alum plate to mount the regulators is something you can machine in mas for little exspense and make it easy for the guys that are buying your flywheel just my 2 cents. DEz nuts
  14. #29
    Aug 2004
    CONWAY SC
    Here's Steve Smith (DS77) 40 amp flywheel. Thanks
  15. #30
    SE MN
    What Dez said!
