Results 1 to 3 of 3
12-06-2013, 02:02 AM #15000 RPM
- May 2008
- Glen Spey, NY
- 402
225 h.o. to a 250 h.o. wiring harness
Hi, Does anyone know if a 2007 225h.o. wiring harness will work with a 2010 250h.o ? Also what is the actual power difference between the two motors? Thanks in advance.
12-06-2013, 06:24 AM #25000 RPM
- May 2006
- 400
- 17
If you are talking about the engine wiring harness, it will not work, the injectors and the ignition system are different. The 250HO is a different cylinder block, 3.4L.
If you mean the boat wiring harness from the keyswitch to the engine, yep, that is the same.
No comparison in power, the 250 has much more torque and hp and a bigger displacement.
12-07-2013, 07:15 AM #35000 RPM
- May 2008
- Glen Spey, NY
- 402
Thank you very much for the reply you answered my question. I did mean from the key to the engine.
