Page 47 of 50 FirstFirst ... 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 691 to 705 of 740
  1. #691
    Sep 2009
    iowa
    I ran mine all summer semi-dry stacked and had no issues with the pump. I have two 1/8" holes drilled to put a small amount of water in the mid.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  2. #692
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by NosBoss View Post
    With can or without?
  3. #693
    Sep 2009
    iowa
    Without the can. I have a bobs exhaust snout on it too.
    1987 evinrude 200xp
  4. #694
    Search dry stacking, loads of posts
    https://www.screamandfly.com/showthr...ry%20stacking&
  5. Likes Captain75 liked this post
  6. #695
    Aug 2011
    I also started up some of the porting I left behind last spring. Areas of attention are transferport entrances and the aim is to reduce turbulece created by sharp edges when the fresh charge is being pushed against the cyl floor and up the transfers.
    Before:
    After (not finished)
  7. #696
    Aug 2011
    What size outlet nipples are you using?
  8. #697
    Sep 2009
    iowa
    Quote Originally Posted by Captain75 View Post
    I cannot remember. The boat is in storage so I can't look at it. I want to say I used 3/4" hose for the dumps.
    1987 evinrude 200xp
  9. #698
    MIAMI FLORIDA
    The ones I've done i taped the adapter 1/2 pipe threads on each side which is about 7/8.. used barbs with no less than 1/2 I/D and used 5/8 hoses routed up and over the top of the heads and out this forces the block to fill before it can dump out overboard, worked for me doing it on my current build too..
  10. Thanks Captain75 thanked for this post
    Likes AZMIDLYF, Captain75, gfinch, phillnjack liked this post
  11. #699
    well I have read loads of different topics on the dry stacking and still nothing to prove any increase in performance ?
  12. Likes Captaincj liked this post
  13. #700
    Jan 2015
    Quote Originally Posted by phillnjack View Post
    From what I have read into this, the big gains are if you really push the motor into high rpm's like 7500+. Beside that, most just like the way the exhaust sounds when its dry. I have read a few claims that it responds a bit better on low end but not much if any top end gains noticed.
    This is what I have read here, and not my personal experience.
  14. Thanks phillnjack thanked for this post
    Likes phillnjack liked this post
  15. #701
    Aug 2011
    Hello!
    Porting going forward, trying to grind a bit every now and then.
    Will soon be finishing up by honing the bores to the specs I got from racer earlier in this thread.
ID:	431101All entrances smooth and blended to the cyl floors.
    Half way up the transferducts there is a severe mismatch and some very rough areas. All that has now been removed and the boost and transferducts are now really smooth. Hopefully this will eliminate a lot of turbulence and thereby add noticeable power...
  16. #702
    Aug 2011
    Food for thought:
    During all this time grinding on this block I can’t really let go of the idea of adding another set of fingers between the exh and main transfers. But, considering the amount of time invested in this block I don’t fell like gambling...
    I found this pic on the net, as a part of a high-end tuning package for a Yamaha Blaster (I think..)
    The slots are fed through holes in the piston, just like an O/B.
    There must be someone in this community who have tried something similar on a 2stroke O/B!?
    Does it work(add power)? Or does it promote short-circuiting of the fresh charge? If it works, there is definately enough room, at least on an OMC looper!
    Ideas?
  17. Likes Laseraddict liked this post
  18. #703
    I don't have a block in front of me but 99% sure you will get into a water jacket grinding fingers there.
  19. Thanks Captain75 thanked for this post
  20. #704
    Ouch
  21. #705
    Aug 2011
    Some final adjustments remaining before final hone and reassembly:
    I have worked alot with the bad casting inside most of the transfer ducts. Most of the imperfections has been removed, although some of the ducts have small areas that can’t be grinded smooth and needs to be filled instead to prevent turbulence.
    In the pic below I tried to explain the troublesome area (due to a crack in the casting mold!?)
    The question is can it be filled with the putty type JB, or the standard slow setting?
ID:	433655Which one? Is the putty good enough? (Easier to apply)
