Results 646 to 660 of 740
Thread: Looper exhaust porting
11-14-2018, 06:27 AM #646
I'm curious as to why not go vertex or similar? They can sure take a beating also without the siezeco problems. Just curious
Laseraddict liked this post
11-14-2018, 06:54 AM #647Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Are those stock OMC piston not forged, it was posted they are? Wisecos aren't the issue.
11-14-2018, 06:57 AM #648
11-14-2018, 06:59 AM #649Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
It least I think it was mentioned?
11-14-2018, 08:17 AM #650Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
11-14-2018, 12:26 PM #651
11-14-2018, 01:01 PM #652
11-14-2018, 01:29 PM #653
That's what I'm runnin in modded 2.5 200. So far so good. Just looked at bores with few hrs on it. Seems be doin fine, theres few other guys using em with good reports, but prob not reving 7k or much more
11-14-2018, 01:32 PM #654
You already have the wiseco so just need to figure it out and get it back together
But Vertex is the way to go..what I have in my new power heads
I had wisecos in my other motors for 15+ years but never ran them above 7200 and still running good when I took them off except the one that ate a Reed stop but that doesn't countLast edited by mrichartz; 11-14-2018 at 01:37 PM.
'84 Checkmate Convincor
11-14-2018, 05:42 PM #655Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
IMO pistons measured 90 degrees from pin, 1/2 inch from bottom. Looks to me maybe not clean enough prior to assembly, ring tip clearance too tight or a cooling issue. IMO when running 2.7 heads on a closed deck engine the gap between the chambers on the heads needs to be filled in like the standard closed deck heads, I also see you have very early style thermostats which may have not been controlling temp correctly, I would get new style with 70HP covers and springs
Captain75 liked this post
11-14-2018, 05:59 PM #656
powerabout, Captain75 liked this post
11-14-2018, 07:13 PM #657Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
11-14-2018, 07:22 PM #658Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
If they're round, clean up hone, new rings, check cooling?
11-14-2018, 07:23 PM #659
11-14-2018, 07:26 PM #660
