Results 601 to 615 of 740
Thread: Looper exhaust porting
10-24-2018, 02:37 PM #601
a bit glazed, but not damaged in any way.
By the upcoming weekend I should have it apart and by then I will post some piston pics.
I’m still a bit puzzled by the disapearing JB Extreme Heat... I probably need to start look for small set screws iot re-stuff the idle reliefs. I don’t really like the idea of having metal pieces in the close vicinity of the moving piston, but I can see any other solution!? Perhaps automotive exhaust repair putty?
10-24-2018, 02:56 PM #602Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Did you power wash the hull and get water in the tank under the tank lid?
Pyro-Puty 1000 is great but $ fir such a small use. If you wanted to do some work in the exhaust chest it could also be used there.
Too small an area on the back side of the relief to get some real welding done?
Or too tight to drill the relief and press fit a pug or thread one in, Allen head ?
1/8 NPT Edelbrock 9129 Internal Allen Head Pipe Plug Fittings or might that lead to a crack? Maybe straight non taperedLast edited by FMP; 10-24-2018 at 05:45 PM.
10-24-2018, 07:53 PM #6037000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
You will also need a 4" or 100mm micrometer to go with the bore gauge. Measuring tools are really not that expensive compared to pistons.
When all you have is feeler gauges then use a piston ring to get an idea of the taper. Push it into the bore different depths with a piston top and compare the end gap.
10-25-2018, 12:14 PM #604
No water in the fueltank!
Concerning the idle reliefs: Straight, non tapered Allen screws could probabably do the trick, question is weather std Locktite thread lock could cope with the heat?? Still can´t understand why the JB Extreme didn´t work when people on this board are using Marine Tex??
I posed another question earlier (lot of q`s...)Do I have anything to gain by cutting the exh liner just below the flange? More space for the gasses to expand at take off!?
Look forward to your thoughts and insights!Last edited by Captain75; 10-25-2018 at 12:17 PM.
10-25-2018, 01:06 PM #605Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
+.020?
10-25-2018, 06:16 PM #606Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,097
- 1008
- 354
- 4297
- 1953
- 7 Post(s)
whats the story on your cooling system, does the engine get hot enough?
10-26-2018, 02:41 AM #607
I haven´t had the possibility to instrumentally measure the temperature.
The heads at least get so warm that it becomes impossible to touch them with bare hands...
I am running a stock 2.7 cooling system, including the diverter valve that is linked to throttle/gear positions. The closed deck poppet valve has been replaced by a 6mm overboard outlet.
FMP: +.020??
10-26-2018, 06:45 AM #608Screaming And Flying!
- Jun 2007
- 9,097
- 1008
- 354
- 4297
- 1953
- 7 Post(s)
10-26-2018, 07:12 AM #609Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Hoping you can reuse your pistons. How cold was your hose water during break-in. You ran two hrs on hose, no load?
10-26-2018, 07:29 AM #6105000 RPM
- Sep 2009
- iowa
- 674
FYI, I put standard JB weld in my bleed holes and ran all summer. Still great compression. Not sure why your Jb extreme didn't hold up.
1975 Hydrostream Ventura II
1987 evinrude 200xp
10-26-2018, 10:46 AM #611
10-26-2018, 11:01 AM #612
Holy crap! What actually melted or what is that?
Coating on the Reed cages?Last edited by mrichartz; 10-26-2018 at 11:04 AM.
'84 Checkmate Convincor
10-26-2018, 11:05 AM #613Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Reed stop melted, reeds touched.
10-26-2018, 11:06 AM #614Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
All cylinders?
10-26-2018, 11:08 AM #615
I can't tell from pic on my phone
That is actually the Reed stop in the first pic?
How hot that have to be to melt itLETS GO BRANDON.... LETS GO BRANDON
