Page 37 of 50 FirstFirst ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 541 to 555 of 740
  1. #541
    Aug 2011
    Lake Mälaren, Sweden
    Blew it up to see the rear adapter hose and looks to be going to bottom of valve. The t fitting that has to hose going to front adapter is not used and adapter is plugged on non power steering engines.
    The 98 carbs came stock with a 72D which has about a .075 hole so with the work you have done and heads you are running a jet drilled (dont like) to .078 will most likely be lean at sea level.
    Thanks for the heads up,
    I will enlarge the mains a bit more!
  2. #542
    Aug 2011
    Quote Originally Posted by Captain75 View Post
    Btw, How big is a 78d? From what I’ve understod its not .078”!?
  3. #543
    Aug 2011
    Ready to hit the water!
  4. #544
    Capt. Please give us the performance gains with the mods you did. I'm interested to see if the rpms go up with the same setup (prop) as before.
    I have been watching your project from the begining and am always learning. Thanks for sharing!
    Gary
  5. Thanks Captain75 thanked for this post
  6. #545
    5 Post(s)
    With a looper you can do more power with same rev range and/or move the power peak up the rev range
  7. #546
    Aug 2011
    Gary
    Finally I had the time to try the new looper in the water!
    I was very careful not to mess the motor up, even so I had to feel the throttle response and I can assure you, I was not disapointed! This is a totally different motor the the previous 2.7 Fingerport. I will get back when I have some more time on the water, but first I need to put on a bigger wheel and check the wot timing with these compression numbers.
  8. Likes FMP, NosBoss liked this post
  9. #547
    Aug 2011
    Tomorrow I will fine tune the ignition and the wot timing.
    How much advance is recomended?
    140psi, 91oct.
    Won’t be running above 6600rpms.
  10. #548
    Sep 2009
    iowa
    18 degrees max.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  11. #549
    25:1 then 40:1 ?
  12. #550
    MIAMI FLORIDA
    I would set that timing around 16. atleast until you get the jetting all figured out, if you end up a little lean +140 compression + heavy boat =bad day, better off safe. I left both of my mod 3l loopers at 16 and they made plenty of power.. Dave
  13. Thanks Captain75 thanked for this post
    Likes racer liked this post
  14. #551
    Aug 2011
    25:1 then 40:1 ?
    Right now running 4% mineral based. It smokes a bit...
  15. #552
    Aug 2011
    Gary
    A little update, but without any real numbers due to break-in process;
    Today I tried a 22” Raker, a prop I’ve had serious bogging issues with when running the 2.7 f/p powerhead. With this ph it just explodes out of the hole, running 16deg timing advance.
ID:	409567Timing adjust using the Reeves method...
ID:	409568On the lake
  16. Likes NosBoss liked this post
  17. #553
    May 2001
    Mooresville NC
    Timing needs to be set at 5k under load. They dont all change the same amount.
  18. Thanks gfinch, Captain75 thanked for this post
  19. #554
    Jun 2002
    winter haven fl
    Nice clean setup.
  20. #555
    MIAMI FLORIDA
    Agree,I'm guessing that waters cooold..
Bob's Machine
