Results 526 to 540 of 740
Thread: Looper exhaust porting
05-16-2018, 07:33 AM #526Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-16-2018, 08:41 AM #527
05-17-2018, 08:52 AM #528
05-20-2018, 03:31 PM #529
NosBoss liked this post
05-21-2018, 06:08 AM #530
FMP liked this post
05-21-2018, 06:34 AM #531
05-21-2018, 07:26 AM #532Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
He has early manifolds with later airbox so he is fine on the hose. Your carbs don't have the inserts for the airbox to hold it in place.
05-21-2018, 02:35 PM #533
05-21-2018, 02:38 PM #534
Looks really nice, what kinda compression did you end up with..
05-22-2018, 12:37 AM #535
05-22-2018, 07:21 AM #536Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Plumbing in photo 1 is wrong. From rear elbow on adapter to bottom of valve, back of valve to heads, front goes overboard. The front fitting on the adapter is an exit on power steering engines and is not used. Do not idle any longer on the hose 2 hrs is already to much. You need to get back pressure on the exhaust and start getting a light load from idle to 1500 and slowly work up.
Captain75 thanked for this post
05-22-2018, 08:41 AM #537
05-22-2018, 12:17 PM #538
if you want to run the late air box on the early carbs you just need to press out two of the brass inserts from the late model carbs and slightly enlarge two of the holes in the early carbs and press in the brass inserts. sorry just read and looked at the carbs and realized you are using late carbs.
1993 Cougar 21ft MTR Superbender SHO
05-22-2018, 03:16 PM #539
Checked today after work.
Motor cold, not running since yesterday.
Butterflies closed(forgot...)
Had to run with all plugs in, Otherwise the starter releases before I get a proper reading?!
#1: 142
#2: 137+
#3: 140+
#4: 137
#5: 142+
#6: 137
I will start by running mains drilled to .078,
#26 midrange orfices, 106 pullovers.Last edited by Captain75; 05-22-2018 at 03:49 PM.
05-22-2018, 04:43 PM #540Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Blew it up to see the rear adapter hose and looks to be going to bottom of valve. The t fitting that has to hose going to front adapter is not used and adapter is plugged on non power steering engines.
The 98 carbs came stock with a 72D which has about a .075 hole so with the work you have done and heads you are running a jet drilled (dont like) to .078 will most likely be lean at sea level.
