Page 34 of 50 FirstFirst ... 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 496 to 510 of 740
  1. #496
    Aug 2011
    Lake Mälaren, Sweden
    Did the other bank this morning. I tried another far less messy method:
ID:	399901Cleaning using the Mrs tops and acetone
ID:	399902Filling using the same syringe
  2. #497
    Aug 2011
    The other day it was time to really start the reassembling process. All parts were examined, refreshed or exchanged with new ones.
    Everything went well until the last piston/rod...
    This is not what you expect when opening NIB stuff
    So disturbing, especially since I have order the parts from the other side of the Atlantic!
  3. #498
    Quote Originally Posted by Captain75 View Post
    That sucks Capt. as I see that in construction way to often.... Its like putting both feet on the brake!
    Gary
  4. #499
    Sep 2002
    Solvang, Calif
    Not uncommon with needle bearings and their cages. I just push it in just like it was assembled in the first place.
    Gary
  5. #500
    I’ve seen way more mixed up damaged new in Box wiseco then I have seen from pro’s stuff. Recently had 3 of 6 wiseco .020 pistons with standard rings in the box. The pistons were not from pro they were From wiseco...
  6. #501
    Aug 2011
    Quote Originally Posted by gfinch View Post
    I would do that too, If there was anything to push back in...
  7. #502
    That's cheezie
  8. #503
    I didn't see one in the pic ...that's why I stated it was like "puttin both feet on the brake" as ya not gonna make one! Sucks
    Gary
  9. #504
    Give ProMarine a call, they'd probably mail you a new bag.
  10. Likes olboatman liked this post
  11. #505
    Captain, I'm sure you thought of that already. Bet they'd like to know. I lost a roller out of a new bag a few weeks ago, turned everything upside down no luck. It must have went into orbit, just gone.
  12. #506
    Sep 2002
    Solvang, Calif
    I guess I was seeing through to the needle on the other side. Maybe take every other needle out...Naaa
    Gary
  13. #507
    Aug 2011
    While trying to find another rod bearing, I’ve done some other stuff:
    Next step; back in the owen iot drop a new bearing into the carrier.
  14. #508
    Aug 2011
    Hello again!
    I decided to change the cranks lower ball bearing aswell while everything else is being replaced.
    What kind of tolerance is needed? The parts lists I’ve found doesn’t say.
    The bearing I removed was a 6308 C3 bearing. The question is wheather to use a bearing with a normal amount of play or if the C3 with added play is needed??
    appreciate your replies!
  15. #509
    MIAMI FLORIDA
    Don't go tighter, it will be too tight when hot , guys that rebuild pressed cranks told me they used c4 fit and have seen longer life.
  16. Thanks Captain75 thanked for this post
  17. #510
    8 Post(s)
    buy a genuine bearing and it will be the correct one
