Page 25 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 ... LastLast
Results 361 to 375 of 740
  1. #361
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by NosBoss View Post
    The early loopers had the limit at 6100-6200. That can be changed with aftermarket power packs.
    I have OMC packs that says "6700", I just wondered where a stock 2,7 produces the most hp, no need to turn 6700 if the power peaks at 6000...
  2. #362
    Sep 2009
    iowa
    I've been told the power falls off hard around 6500 unless some extensive porting has been done.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  3. #363
    Aug 2011
    Thanks, just the information I needed!
  4. #364
    Aug 2010
    N.Florida
    My close to stock motors always ran the best mph propped between 6200 and 6400. You may be able to go a little bit higher with the work you've done I'm not sure.
  5. #365
    May 2014
    Missouri
    Did you match your casting ports to the ports in the sleeve? On my v4 the two are WAY off. I would be afraid of cutting them back that far.
  6. #366
    8 Post(s)
    Quote Originally Posted by N Wolf View Post
    In many cases it s the sleeve thats in the wrong place, well worth heating the block and fixing that.
  7. #367
    Sep 2009
    iowa
    I opened up my block to match my sleeves on my 3 liter. It had equal amounts on both sides of the port. Not sure on my 2.7 yet, but hopefully it's the same.
    1987 evinrude 200xp
  8. Likes Laseraddict liked this post
  9. #368
    Aug 2011
    My sleeves were all well centered, so I grinded the block to match the sleeves.
    Another thing;
    Pullover tubes, how would they be a benefit to me? Do they richen up everything? Even the mains?
    I'm trying to get a snappier and more chrisp throttle response when using a bigger prop.
    Besides that I'm glad to report that the mods described in this thread have made a huge improvement! I have got a few(2-3) hours on the engine now, and it seems like it only gets stronger, perhaps due to rings seating etc.
    I haven't really tried the topspeed yet, I don't want to stay at WOT for more than a couple of seconds. It reaches 6000+ without problems, with a lot of trim left!
  10. #369
    Aug 2010
    N.Florida
    Reducing the pull over will bring the main in at a lower rpm and richen the mid.
  11. #370
    I was told Every .010 smaller pullover will make the mains act about 1/2 size bigger.
  12. #371
    Aug 2011
    Hello friends!
    Break in is in progress!
    I started with jets drilled to 0.071", drilled another set to 0.0669 which made a big improvement!
    Next step is factory, non drilled jets because It feels like I'm getting close.
    Ordered 64D's for the upper four cyls, 65D's for nr 5 and 6.
    Ordered the pullover tubes 322812 aswell, as a possibility to rich up just a bit.
    Hope this sounds more right than wrong, considering the mods I made.
  13. #372
    Aug 2011
    This thread is coming to an end...
    All internal job is done, break in procedure finished, maybe stepping down a couple of jet sizes further(running 65D right now).
    Last touch; looks...
    New paint, new decals, thanks to Garzon studios.
    The backside is still drying...
    I wanted to add "2.7L Fingerport", but I couldn't really get it right and got tired.
    Tomorrow the cowling is going back to the paint shop to get the decals clear coated.
  14. #373
    Real nice job Cap!!!! You get an attaboy-- been watching and have learned a LOT. Thanks Gary
  15. #374
    Aug 2011
    Thank you Gary!
    It took a while to do all this, but when out cruising with the Mrs and my three sons, its worth every hour. My oldest son, Lukas 12, just loves the "new punch" and sound when you bury the throttle
    //Anders
  16. #375
    Aug 2011
    Its hard to say, but I think maybe the motor is a bit stronger in the lower rpm range when running pullover #106, but also clearly a bit rich on top. I think they were marked 106, they are called 322812 in the list.
    Mains are 65D, idle #48, mid #14, airbox with baffle, fingerports added, all ports and rodslots matched/worked for smooth flow. Stock compression. Midbore carbs.
    Anyone who can tell me the size of the pullover size in the carb body, I am having a hard time with your inch measurements
    //Anders
