Results 316 to 330 of 740
Thread: Looper exhaust porting
04-29-2014, 08:28 PM #316Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
You only need a rod and then work out how to squeeze the sides together using a 3 angles on each side of the rod. The consumer tool screws up and the factory one is spring loaded as I remember it.
04-29-2014, 11:36 PM #317
I have no alignment tool.
Just tryin to do it according to the book.
On most of the rods/caps I can get it flush on one side, but with a slight, feelable missalignment on the other, how is that possible?
I guess I will have to manage with the best I can do since its time to get boat in the water.Last edited by Captain75; 04-30-2014 at 12:40 AM.
04-29-2014, 11:42 PM #318Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Put a small amount of pressure on the bolts, get a pencil to check the 6 alignment faces, get a tiny hammer to gently tap the cap to align it.
04-30-2014, 03:24 AM #319
Thanks for the tips!
The procedure pretty much describes my work so far.
I have no problem sideways(the small alignment areas) my problem occurs along the two bigger areas. I seem to get it slick on one side, but still some off alignment on the other...
I have thought about using a clamp during the torque process.
My intention is to get the engine running after this weekend, right now I traveling to London with my 10year old son(He's about to see one of the worlds great cities for the first time)and I am trying to gather info on the process. In worst case I will have to use another rod, something I don't want to do due to my balancing effort during the rebuild.
I don't think it is possible to find an alignment tool in this country.Last edited by Captain75; 04-30-2014 at 03:30 AM.
05-06-2014, 11:01 PM #320
I managed to get them right, I think.
Since I am really close to start, I have some more questions(I might have asked similar things before..)
- Do I have anything to benefit by removing the airbox baffle due to the mods I have done(described in this thread)
- What would be the proper jet size the use, right now I have stock 62D installed.
I just realized that I have another question;
I torqued the main bearing bolts a bit to much, not that the threads got destroyed, but a bit to much according to specs(found the specs to late..)
What do you guys think, shall I loose the bolts one at a time, add new sealer and retorque them to proper specs, or just leave them as they are?
Port map...
Powerhead in place...Last edited by Captain75; 05-07-2014 at 01:35 PM.
05-10-2014, 04:45 AM #321
05-10-2014, 05:43 PM #322Member
- Jun 2012
- Canada
- 84
What a fun thread to follow.
Good luck with the first start!
05-10-2014, 06:14 PM #323"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
05-11-2014, 12:55 PM #324
05-11-2014, 06:36 PM #325
05-11-2014, 09:27 PM #326
I'm sure you guys already hit this topic somewhere between page 1 and 22 but I would definitely start with 6 jet sizes up and 6 down,6 down idle and mid,6 up mains.
05-12-2014, 06:34 AM #327
05-12-2014, 07:42 AM #328
I didn't want to comment on jetting b/c I'm no expert but I normally start with .078 read the piston tops before running it hard then start jetting down.
05-12-2014, 03:17 PM #329
05-14-2014, 10:04 AM #330
I've never jetted one with the baffle. Only the new style air box. '93 and newer. I think that the motors with the baffle came jetted about .010 smaller but that is a different carb also.
