Page 17 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 ... LastLast
Results 241 to 255 of 740
  1. #241
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by Onetime View Post
    Do not use the spring hone on your bores especially with the finger ports. You need a key way hone to properly hone the engine bores.
    Good advise. Expensive but it's the only way to hone cylinders with ports in them. Any spring hone and ball hones drop into the ports while rotating. Not good
    Drop into the ports while rotating... Isn't that the idea using a ballhone?
    Ports get chamfered and bore gets hatched? That was the idea that I got when I did som research.
    The stones attached to my spring hone are so long(100mm)that I can't see them get stuck in the fingers.
  2. #242
    8 Post(s)
    ball hone has a few uses
  3. #243
    Austin Tx
    You are correct on the ball hone.
    Spring hones have a tendency to chatter and leave a crappy finish.
    You have gone this far, invest in a ridged hone or visit a machine shop.
  4. #244
    Aug 2011
    So what you guys say is that should stay away from my brand new 120grit flexhone tool?
    unfortunately I can't find anyone with a rigid hone over here, everyone seems to be using the three armed one. This annoys me, Motor has no scores or wear whatsoever, just needs to be deglazed to seat the new rings!
  5. #245
    Aug 2010
    N.Florida
    You can get a rigid hone off ebay, they're not that expensive. What pistons are you using?
  6. #246
    May 2001
    New Hill, NC
    Quote Originally Posted by Captain75 View Post
    120 grit seems pretty coarse. Wiseco reccomends to finish hone with 280 grit.
    Tony Brucato
    (919) 718-0249
  7. #247
    Aug 2011
    Quote Originally Posted by wanagofass View Post
    stock pistons, modified for fingerports.
  8. #248
    320 followed by a plateau brush, and absolutely no synthetic oil for 50 gallons of fuel.
  9. Likes Laseraddict liked this post
  10. #249
    Jan 2003
    Georgetown,SC
    Send it to a qualified machinist ,who has the training,experience and equipment,may cost you more but worth it in the long run,just my 02 cents.
    09 STV
    92 21 MTR Cougar,300 xs
    85 17 action
    90 26 regal
  11. #250
    Thats a bingo...
  12. #251
    Aug 2011
    Thats a bingo...
    I will try to find a 3 1/2" 320grit flex hone then. Hope it will work with the fingerports.
    Rigid hone is hard to find over here, sunnen can be found but they are way out of budget...
    I initially asked a flex hone dealer here in sweden, he said the 120grit was the grit I wanted, it was supposed to be "within most manufacturers specs" Apparently I was fooled!
  13. #252
    8 Post(s)
    is the plateau brush the nylon one?
  14. #253
  15. #254
    Aug 2011
    Last check before I order; 240 or 320 grit? (Steel bore and stock pistons)
    Will it work with the fingers? (Can't seem to find any rigid ones over here)
    About drystacking: if the idle relief holes high on the sides of the tuner, and the ones on the back were closed, wouldn't that mean that no water enters the exhaust stream?
  16. #255
    Aug 2011
    Forgot an issue in my last post; pistonrings...
    I am doing preparations to drill fingerport windows and I want to get rid of the old rings.
    The upper ones are easy, the lower ones on the other hand are badly stuck, how do I get rid of them without having to break the rings? How about cleaning -scotch brite? Diesel?
    Funny thing is that all cyls had 100+ psi with all the lower rings totally stuck and a bad starter battery...
