Results 16 to 30 of 740
Thread: Looper exhaust porting
11-26-2013, 12:20 PM #16
5000 RPM
- Aug 2009
- Florence SC
- 249
11-26-2013, 12:46 PM #17
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
.150 wider on each exhaust port at the top, make sure you radius them when finished. Clean up the rod slot and match the intakes being careful to maintain original angle since you are not looking for a high rpm engine.
11-26-2013, 12:57 PM #18
5000 RPM
- Aug 2009
- Florence SC
- 249
Just starting a v4 looper for a 15' allison,
Any thing different on the V4 ?
Will the V8 Finger ported piston w/ block mods work ok in the V4, or is there a better direction ?Last edited by thornl01; 11-26-2013 at 01:02 PM. Reason: spell
11-26-2013, 01:00 PM #19
5000 RPM
- Sep 2009
- iowa
- 674
What needs to be done to the roof angle of the intake ports for higher rpm?
1975 Hydrostream Ventura II
1987 evinrude 200xp
11-26-2013, 01:40 PM #20
4mm for each window...
have started matchporting transfer and boostports aswell, pics will be coming soon.
11-26-2013, 01:44 PM #21
11-26-2013, 04:25 PM #22
11-26-2013, 08:41 PM #23
7000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
11-26-2013, 11:45 PM #24
7000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
.03937 is plenty accurate for almost anything done in a machine shop. Especially since there are a couple of zeros after the 7.
And 25.4 is more than OK, it is the absolute definition of millimeters per inch and provides a perfect conversion.
11-26-2013, 11:58 PM #25
6000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
Heres a good conversion spreadsheet I use at work a lot.
http://www.elivermore.com/bills_conversions.xls
11-27-2013, 12:16 AM #26
6000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
39.37 inches per meter was the old accepted standard until the late 1950's. 25.4 mm per inch is the current standard for conversion. In any case there is only .0002% difference between the two standards.
11-27-2013, 09:35 AM #27
11-27-2013, 12:56 PM #28
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
You need an angle head to do the roofs of the transfers.
Higher rpm you the roof angle gets closer to 90 degrees and transfer/boost/finger port heights change a bit
11-27-2013, 04:43 PM #29
Clean up the rod slot...
on small high revving case-fed motors, I have ported/created a "direct passage" from the crankcase(rodslot)to the transfer boost/aux-port, this procedure has been succesful by allowing the fresh charge to enter direct into the boostport as soon as the piston starts its upgoing movement.
Do you have any experience of this on outboards? In this case the boost port don't have to rely on the piston-window...
The yellow tape in the pic is an attempt to describe my idea
11-27-2013, 05:13 PM #30
5000 RPM
- Aug 2009
- Florence SC
- 249
Fingerports or not ?
