Page 14 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 ... LastLast
Results 196 to 210 of 740
  1. #196
    Aug 2010
    N.Florida
    That's just an exhaust idle relief.
  2. #197
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by wanagofass View Post
    Ok, but how does the water get into the exhaust housing, if not throught these holes?
  3. #198
    Aug 2002
    florida
    There are holes in the adapter plate that need to be plugged with epoxy. Then the water needs to be rerouted out the side and away from the motor. I usually drill an 1/8" hole in the epoxy for a lake motor to keep the paint from burning on your mid. You can adjust the overflow to help keep heat in the motor. maybe someone on here has one off they can take a picture. As far as that tuner you will need to cut that way back if you plan on a snout. The water pump will be exposed but I have never melted one.
  4. #199
    My brother managed to melt the hell out of one on is 15" mid drystacked. It still ran but the housing was trashed. I always aim the dumps at the water pump to keep it cool.
  5. #200
    Aug 2010
    N.Florida
    Aug 2011
    Mine looks like this, still can't see where the water enters the exhaust apart from the idle relief holes!?Click image for larger version.
ID:	290148Click image for larger version.
  7. #202
    Aug 2010
    N.Florida
    I think that's a 2.7 adapter, I've never dealt with one of those. You can stick a water hose in the top were the water drains out of the heads and see where it comes out the bottom. You'll probably have to take the water inlet plate off the bottom.
  8. #203
    Aug 2011
    I've cut my first fingerport during this afternoon, came out fine, will post some pics later.
    concerning the holes in the side of the liner; they are the only way in for the water that enters the exhaust! In my case, since I have drilled the holes in the mid(just below the pan)all the way throught, gives water four entrances into the exhaust.
  9. #204
    Aug 2011
    First cyl accomplished...Click image for larger version.
  10. Likes phillnjack liked this post
  11. #205
    Sep 2009
    iowa
    Wow! Nice job!
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  12. #206
    Aug 2011
    Port bank accomplished!
    I need some advice on port timing;
    the main transfers open slightly earlier than the boostport, how about the fingers?
    should I set the fingerports like the boost, aimed at the sparkplug?
  13. #207
    Jul 2005
    Regina SK. Canada
    Could you give us a walk through on how you cut these finger ports ? Did you use a jig , pattern layout , freehand ? They look nice and straight and uniform, good job ! My guess is they should open at the same time as the boost port.
  14. #208
    Aug 2002
    florida
    the two holes in front of the studs on each side need to be plugg and a pipe fitting installed through the side. putba hose through ther from the top and you will see how the watr flows
  15. #209
    Aug 2011
    Quote Originally Posted by baldad45 View Post
    Go back in this thread and you will see some pictures showing how they are done, I will post some more to show the procedure.
  16. #210
    Aug 2010
    N.Florida
    I'm kinda confused. What dumps are you talking about?
