Page 41 of 50 FirstFirst ... 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 601 to 615 of 740
  1. #601
    Aug 2011
    Lake Mälaren, Sweden
    How did it look when the original pistons came out?
    a bit glazed, but not damaged in any way.
    By the upcoming weekend I should have it apart and by then I will post some piston pics.
    I’m still a bit puzzled by the disapearing JB Extreme Heat... I probably need to start look for small set screws iot re-stuff the idle reliefs. I don’t really like the idea of having metal pieces in the close vicinity of the moving piston, but I can see any other solution!? Perhaps automotive exhaust repair putty?
  2. #602
    Did you power wash the hull and get water in the tank under the tank lid?
    Pyro-Puty 1000 is great but $ fir such a small use. If you wanted to do some work in the exhaust chest it could also be used there.
    Too small an area on the back side of the relief to get some real welding done?
    Or too tight to drill the relief and press fit a pug or thread one in, Allen head ?
    1/8 NPT Edelbrock 9129 Internal Allen Head Pipe Plug Fittings or might that lead to a crack? Maybe straight non tapered
  3. #603
    Central Florida
    Quote Originally Posted by Captain75 View Post
    I use a pretty simple method.
    By using the rigid hone you can feel in the operating hand when the bore has shifted from oval to round.
    Final size is determined by sliding the piston into the cyl upside down.(piston skirt being wider than the piston top) I use a feelet gauge to determine the play between cylinder wall and piston skirt. I have had the possibility to use a borrowed bore gauge in the past, now I have one heading my way by mail.
    You will also need a 4" or 100mm micrometer to go with the bore gauge. Measuring tools are really not that expensive compared to pistons.
    When all you have is feeler gauges then use a piston ring to get an idea of the taper. Push it into the bore different depths with a piston top and compare the end gap.
  4. #604
    Aug 2011
    No water in the fueltank!
    Concerning the idle reliefs: Straight, non tapered Allen screws could probabably do the trick, question is weather std Locktite thread lock could cope with the heat?? Still can´t understand why the JB Extreme didn´t work when people on this board are using Marine Tex??
    I posed another question earlier (lot of q`s...)Do I have anything to gain by cutting the exh liner just below the flange? More space for the gasses to expand at take off!?
    Look forward to your thoughts and insights!
  5. #605
    +.020?
  6. #606
    8 Post(s)
    whats the story on your cooling system, does the engine get hot enough?
  7. #607
    Aug 2011
    I haven´t had the possibility to instrumentally measure the temperature.
    The heads at least get so warm that it becomes impossible to touch them with bare hands...
    I am running a stock 2.7 cooling system, including the diverter valve that is linked to throttle/gear positions. The closed deck poppet valve has been replaced by a 6mm overboard outlet.
    FMP: +.020??
  8. #608
    8 Post(s)
    FMP: +.020??
    Sounds warm enough then
  9. #609
    Hoping you can reuse your pistons. How cold was your hose water during break-in. You ran two hrs on hose, no load?
  10. #610
    Sep 2009
    iowa
    FYI, I put standard JB weld in my bleed holes and ran all summer. Still great compression. Not sure why your Jb extreme didn't hold up.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  11. #611
    Aug 2011
    Intense heat on the inside...
    Cause: blow-by?
    I have not had a single lean snease!
  12. #612
    Jul 2005
    AZ
    Holy crap! What actually melted or what is that?
    Coating on the Reed cages?
    '84 Checkmate Convincor
  13. #613
    Reed stop melted, reeds touched.
  14. #614
    All cylinders?
  15. #615
    Jul 2005
    AZ
    I can't tell from pic on my phone
    That is actually the Reed stop in the first pic?
    How hot that have to be to melt it
