Page 26 of 50 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 376 to 390 of 740
  1. #376
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by Captain75 View Post
    Its hard to say, but I think maybe the motor is a bit stronger in the lower rpm range when running pullover #106, but also clearly a bit rich on top. I think they were marked 106, they are called 322812 in the list.
    Mains are 65D, idle #48, mid #14, airbox with baffle, fingerports added, all ports and rodslots matched/worked for smooth flow. Stock compression. Midbore carbs.
    Anyone who can tell me the size of the pullover size in the carb body, I am having a hard time with your inch measurements
    //Anders
    No ideas?
  2. #377
    Aug 2011
    Time to wake this thread up again...
    My 2.7 looper (describen in this thread) has been used successfully for another summer!
    New mods this summer was increased compression by cutting the heads(1mm) alongside with the head shave, I had the airbox gutted and carbs rejetted.
    By midsummer, I tossed the VRO, and went Holley Blue, which gave me a couple of hundreds up top(clearly a bit sarving before at WOT...)
    My motor runs fine, but according to the compression readings, I think its time to renew the cylinder bores beyond honing and rings... Compression right now is 105-107 on all six.
    My intention is to get the cylinders bored to 3.685 in order to get the primary and secondary compression up and in the same time continue the hunt for 300hp's
    About pistons; I got a fairly good deal on 1993-2000, fingerport looper pistons from Vertex, are they any good? Can I use them in my application?
    When I cut my fingerports, I placed them "in the middle", between the main transfers and the boost port, will their location match the f/p holes in the above pistons?
    About porting;
    I want to make my f/p's a bit deeper before boring the sleeves, how deep can I go, measured from the stock 2.7 sleeve?
    //Anders
  3. #378
    The last stock 2.7 I had compression was around 115. We run 140 with no issues on 93 I think your going to need to up compression to get near 300.
    Match the piston ports to the fingers make them as wide and flow in the same direction.
    Do do you plan on removing the bridge in the exhaust port?
  4. #379
    Aug 2011
    If I was to keep the current bore size and further increase the compression by shaving the heads even more, where is the limit? I have already shaved 1mm(0.039")
    Since I am not planning to turn more than appx 6500rpms, do I have anything to gain by removing the exhaust bridge?
  5. #380
    Aug 2011
    Started porting today!
    Decided to use the other 2.7 block I have in the garage, a really fresh one which has never seen salt water.
    I started by adding the fingerports in order to reduce the risk of messing the fresh bore up.
    I am trying to cut the fingers a bit deeper and and a bit higher to better fit the increased boresize.
    Right now I am trying to figure out weather to widen the exhaust windows (appx .150 at the top, taper down to stock)or to leave them?
    I dont plan to turn the motor much passed 6500, I want huge torque in low-midrange, so I can turn bigger wheels.
    I have read Racers article on how to reach 300hp's, but perhaps thats out of reach if you don't want to turn higher rpms?
    At last I found a shop to bore my cylinders! The shop want the pistons in advance in order to maintain the proper piston to cylinder clearance, now I must find the right pistons for my application.
    Can any of you guys point me in the right direction when it comes to pistons?
    I want the 3liter pistons with fingerport holes in the skirts, and the ring stops located in the fingerport area. What are these called/numbered?
    //Anders
  6. #381
    8 Post(s)
    Dont give your boring guy a piston he has no idea of the piston to bore clearance.
    You just tell him what size hole to finish.
    Dont cut the finger ports till you have the pistons to ensure the pin is in middle ish of the finger.
  7. #382
    Sep 2009
    iowa
    I will check my wiseco pistons when i get home. I thought they had the ring locator pins in the fingers.
    Where is the article Racer wrote about achieving 300hp?
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  8. #383
    Aug 2011
    Attachment 330468Took the old jig out...
ID:	33047030 min later...
ID:	330471After 1hr, first cyl ready
  9. #384
    I haven't played with a 2.7 in years those sleeves are thick!
  10. #385
    Just curious..... approx. how thick would they be? I can see the aluminum where they are ground thru. Thanks Gary
  11. #386
    7 Post(s)
    Think enough to bore to 3.0 (3.658") specs which is about an 1/8" of meat.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  12. #387
    2.7 is 3.50
    3.0 is 3.685
  13. #388
    Jun 2001
    South East Georgia
    Here are some Big finger ports in a 2.7.Click image for larger version.
    TMc
    1984 Allison XR2002
    1987 2.7 Fuel Injected Evinrude
    16" Taylor mid
    Brucato ACU.
  14. Likes BeefKid, Laker, Laseraddict liked this post
  15. #389
    Gary I was woundering because thats about what I have (1/8") thickness with my late 70s 2 cyl OMCs I play with. Thanks Gary
  16. #390
    Aug 2011
    Quote Originally Posted by TMc View Post
    Beautiful!
