Results 1 to 8 of 8
    Chandler, AZ (home of the IHBA FINALS)
    Allison XB2002 setup
    Okay, time to setup my hull correctly. I have a 1994 XB2002 Comp. I converted it from a center steer/ sm console to a side steer/ large console. I play without a trolling motor, and when I fish, the boat is setup with a light OMC trolled (you know the one a lot of Ally/Bullets run). I have two jack plates, a fixed 4" and a 6" rapid jack. I run a bunch of different props, mainly 24" drag and et 3 & 4 blades, as well as a 30 et for top end duty.
    How would you set it up?
    For fishing. Running with a 250# driver, 175# co fisher, about ten rods and a few tackle boxes (say 75# of total tackle). Full tank of gas and full live well of water ( and hopefully fish). Trolling motor and two big trolling motor batteries.
    For speed. One driver 250#, no trolling motor/batteries, dry live well, 1/2-1/4 tank of gas.
    Mar 2004
    Leesville, SC
    We will also need to know what engine and lower unit you are running as well as if the lip on the pad is stock or not.
    Jul 2010
    Ankeny Iowa
    I always run my cranking battery in the port rear compartment. I also usually have all my tackle in that compartment, and anything else that will fit. I don't have as much stuff as you though. When I fish with someone else I usually put an additional battery in the same compartment, and move some of my tackle to the other side. I put my buddy behind me in the center. It makes it a lot easier to get up and down while fishing, and his weight doesn't affect the balance too much. If I were going to run 2 troller batteries I would put both in the center compartment, or one in the center and one on the port side. The balance usually is pretty close when I switch from one setup to another, but I'm still always moving stuff around to fine tune it.
    2.5efi, stock sportsmaster, stock pad. Propshaft even with pad.
    daytona beach
    are u asking for motor height and prop setup or weight distribution?
    May 2002
    Harriman, TN
    Quote Originally Posted by vishus View Post
    How does it run now? Sounds like you are close on everything. Tweak a little bit here & there as you go.
    10" to 12" is common. Even or above a little is common too.
    I have 12" setback and probably 1/4 above. It does everything nice with most of the props I have tried.
    Both batteries are in from of the gas tank.
