Results 106 to 120 of 249
Thread: Evinrude Super Strangler!
12-14-2013, 08:43 AM #106Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
12-14-2013, 04:42 PM #107Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I would as there was no impact relief in it and easy to get
12-14-2013, 05:11 PM #1085000 RPM
- Feb 2012
- Canada
- 346
12-14-2013, 05:13 PM #109Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Bull they V4s had a pressure back top ring while the ccc had upper and lower groove rectangle rings, they were the same as the lower ring if memory serves me right. I may still have some of the rings. Both pistons came with the scallop however the ccc would last longer at high rpm because the rings kept it straighter in the bore. We did run ccc pistons in the later 4s that we built.
Original equipment on these engines did not use a merc trim ram I believe they were made by prestolite.
12-14-2013, 05:28 PM #110
Did the Strangler lower units have a 13, or 15 spline shaft?
1986 20 ft. 8 in Shadow Tunnel Vee
86 Rude XP 200 Looper
10" Quicksilver Para - Lift Hydraulic.
Hoss 15 x 28p. HPD & 14 & 3/4 x 27p. Yammie Drag 4
Ron Hill Custom 15 x 28p. 4 Blade O/T Cleaver, Mazco 15 x 28p. 3 blade Cleaver
Hydromotive Intimidator Q4 15 x 27p.
12-14-2013, 05:54 PM #111Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-14-2013, 06:52 PM #1125000 RPM
- Feb 2012
- Canada
- 346
I'm just saying what I used was the merc stuff (and so did a few others)
12-15-2013, 08:06 PM #113Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
I'm assuming that the mid section below is the Super Strangler which were only 15" I believe. I can see now where the single hydraulic trim ram was anchored.
So it looks like you bolted a metal receiving platform to the boats transom with 4 through bolts and then the trim ram attached to where the arrow points.Last edited by Greg G; 12-15-2013 at 08:24 PM.
12-15-2013, 08:21 PM #1145000 RPM
- Aug 2009
- Florence SC
- 249
Att: John Tiger,
What would be the chance of a picture & possible dimensions of the tuna ? Please
12-15-2013, 08:37 PM #115
[QUOTE=racer;2570158]Bull they V4s had a pressure back top ring while the ccc had upper and lower groove rectangle rings, they were the same as the lower ring if memory serves me right. I may still have some of the rings. Both pistons came with the scallop however the ccc would last longer at high rpm because the rings kept it straighter in the bore. We did run ccc pistons in the later 4s that we built.
Allen i didn`t know that about the ccc piston rings. Yep, The V-4 GP pistons we used had the power back top ring located high on the piston. We tried to get some before the large scallop was cut so we could use our smaller cut but no luck.
I had a Strangler once. Bought a wrecked Scotty hull with it on it and was a very reliable lil motor. I rigged it on one of Wayne Weeks old Vandel and it was a competitive rig in the 100ci unlimited class. I did try it with the 8 barrol set up but didn`t work very well in the drag racing segmint of our program. Did well off the start boat in closed coarse races tho. We ran the club foot. The owner decided one day to put the 15/17 speedy on and blew it over at Lake Buhlow.
DB
12-15-2013, 09:10 PM #116
12-15-2013, 09:11 PM #117
[QUOTE=thornl01;2570552]Att: John Tiger,
What would be the chance of a picture & possible dimensions of the tuna ? Please[/QUOTE
Sorry, I don't have a spare one available. It's mounted in the engine at this point.
12-16-2013, 12:49 AM #118
i have one of the kr- 15 with both lower units that i will start to restore soon
i want to put it on a boat and run it, the intake and carbs were gone when i bought this engine i had it in my shop for 25 years would you run the lower units i afraid that if something happens could not find any parts to fix thanks for the pictures and info RANDy
12-16-2013, 06:14 AM #1196000 RPM
- Jun 2009
- Georgia
- 1,006
- 232
- 9
- 365
- 39 Post(s)
Guys: The factory race engine of the early '70s used 2 Mec power trim units; one for trim (in & out) and one for lift. I actually designed and built a single pump unit as a weight saving that did both, but since Blanchard didn't design it, it was never used. The V-4's put out 180/185 PROPSHAFT hp at the time. That's why when the rotary hit at 265 PROPSHAFT hp they were so dominant.
12-16-2013, 07:13 AM #120
Who`s Blanchard? Sounds like corporate politics/egos involved.
DB
