Results 91 to 105 of 249
Thread: Evinrude Super Strangler!
12-10-2013, 10:18 PM #91Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
12-11-2013, 09:15 AM #925000 RPM
- Feb 2003
- 283
- 30
- 85
- 3 Post(s)
Parts book lists the fowling
RPM range 6400-6800
weight 267
Transom height 22"
Gear ratio 14:23 Std - 1:1 optional
Bore and stroke 3.5 x 2.588
Ring Gap upper .020-.022 lower .017-.020
12-11-2013, 06:29 PM #93Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Very cool information keith, thanks! If there is anyway to snap a photo of that information out of the book and post it that would be great. Here are three photos of what I believe to be KR15 Super Strangler race motors, named after Charlie Strang who I traded an email with last week. Two motors have the factory wing plate system in place as well. I am not familiar enough with the lower units to know if all three pictures show the "Clubfoot" 1.65 gear lower unit. Someone will know.
12-11-2013, 07:43 PM #94
The right and left photos show the engine with the clubfoot gearcase. The middle photo shows the sprint gearcase.
12-11-2013, 07:55 PM #95Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Thanks a lot John. Another question. I am looking at the photo below and there does not seem to be any traditional clamp bracket for the Super Strangler/Stinger GP 8 pumper race motors. What is going on with the piece that is bolted to the transom?
12-11-2013, 10:28 PM #96
These engines had a very unique mounting system. They had two brackets that tied into the steering tube, and went up and over the transom and bolted through from the inside, using serrated blocks for adjustment. The through-transom trim bracket (the part your arrow points to) provided the bottom bolting platform, and the outer thrust stability for the engine swivel bracket.
12-13-2013, 11:54 AM #97Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Interesting. So with the Super Strangler power "trim" while running a race was facilitated by rams pushing against the transom of the boat hull itself. I guess then that there were two ram cylinders, one on the right and one on the left. Never heard or seen that before but it was a race motor. Any idea what the diameter of a Clubfoot 1.85 lower unit was at the blow out ring?
12-13-2013, 01:10 PM #98Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
all the OMC race motors are similar, one trim cylinder anchored inside the transom and going through a hole in the transom to work on the swivel housing from sst45 to F1 V8
OMC also pioneered the trim in the swivel tube as well so they trim up and down vertically on some models
12-13-2013, 01:47 PM #99
Which model was it that had the hydraulic up/down as well as in out? 20 or so years ago, I looked at a Hydrostream Vixen that was rotting away with a 4banger OMC with this mid on it. I have always kicked myself for not buying it, but at the time I did not know what the motor was.
Jason
Outboard Junkie
12-13-2013, 02:25 PM #100Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I think it came out on the KR 15 Super Strangler so that was about 73 I think, plenty of guys on here that will know that better than me
12-13-2013, 02:40 PM #101Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
I didnt read thru all the replies so this may have been mentioned. Late development on these engine saw a 15/17 lower become available, they remain a rare item. The lower unit shape also changed shortly after the photo on the first post. At one point I building these engines for a few people, we even had a 3.625 bore version with the 8 barell set up. It was asked what rpm the 6400-6800 listed is low, we used to run them 7200 at the 7HR parker enduro and 75-77 sprint racing.
12-13-2013, 07:55 PM #102Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
I'm not sure if anyone has a better picture but that is a very cool power trim system. When I looked closer at the picture I could see in #1 the transom lip "anchor pivot" point and then in #2 the single hydraulic ram for in and out trim angle. I guess a pic would tell but the straight ram trim was probably very simple yet heavy duty to take the beating.
12-13-2013, 08:54 PM #1035000 RPM
- Feb 2012
- Canada
- 346
it was usually a merc Tower of Power ram--at least mine was.
12-13-2013, 09:24 PM #104Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
12-14-2013, 06:19 AM #105
Did the 2.4L CCC use the same pistons as the last V-4 Stranglers? We used to order them as what was called an "OMC V-4 GP" piston for our 1978 235. That may not have been the proper name for them nut the man on the phone undertstood what we wanted. They had the large half mood cut in the skirt that was not desireable for our needs but they offered way more compression compared to stock plus they were forged instead of cast.
DBLast edited by Da Bull; 01-03-2019 at 09:11 PM.
