Page 16 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 226 to 240 of 249
  1. #226
    I believe the old Havasu films show them but in a mad pack of engines
  2. #227
    8 Post(s)
    Very similar to a 73 135 head
    assuming this is a 135 and a CCC was it better than a KR
    Attached Thumbnails Attached Thumbnails 135 combustion chamber.jpg   ccc head cut.jpg
  3. #228
    Other than the cut they look the same
  4. #229
    Sep 2016
    McHenry,Illinois
    Yea...looks like the one on the right would be a much higher compression head.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  5. #230
    May 2001
    Hickory NC
    That 135 head has had a bit done on exhaust side. KR and CCC really close, never did mold them to see if exact but to the eye very close.
    Power yes I have cut the bridges out but saw very little gain and lived much better with them.
  6. Thanks powerabout thanked for this post
  7. #231
    8 Post(s)
    Is that CCC head stock or is it milled?
  8. #232
    May 2001
    Hickory NC
    If cut not very much.
  9. Thanks powerabout thanked for this post
  10. #233
    8 Post(s)
    which part of that chamber should be down to 040" or so clearance and which parts should be left to make up the chamber for whatever psi you want?
    Does it work if you apply squish to the exhaust side of the piston?
  11. #234
    May 2001
    Hickory NC
    Entire intake from surface around radius to flat on floor along with the angle on exhaust side. The .040 would be minimum amount.
  12. Thanks powerabout thanked for this post
  13. #235
    8 Post(s)
    the exhaust side of the piston is never very flat to match the head plus slightly higher in the middle
    In most cases the pinch would be inside and not out the outer edge of the piston I would think?
    Seems a little work on the head on the exhaust side could be done to get a nice squish on both sides of the piston?
  14. #236
    Aug 2009
    mpls,mn
    Quote Originally Posted by Da Bull View Post
    Man I love talking about these old engines. I also miss the loud howl of a high RPM V-4 X-flow. Wayne Weeks had one on his Vandal that was a cut 13inch mid (I had him cut me one just like it for my V-6) and pistons/sleeves for a 160 ci V-6. I think he told me that it came out to 110ci. That mutha would haul but.
    https://youtu.be/PJldRUYzo7o Sounds great if ya crank it up,12 inch formula vee mod motor.
  15. Likes FMP liked this post
  16. #237
    Love that v4 sound
  17. Likes racervboat, DanUmbarger liked this post
  18. #238
    Jul 2004
    Connecticut
    Here, I believe, are some details on the Super Strangler Evinrude which I also believe was identical to the Johnson Stinger GP
    Bringing it back up 6 years later!
  19. #239
    Any pics of the piston???
  20. #240
    8 Post(s)
    same mod in Racers 9 pages piston I think
