Results 241 to 249 of 249
Thread: Evinrude Super Strangler!
03-30-2019, 08:59 PM #241Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
He mentioned cut back 0.030". I've looked for it , I think I've read and seen a pic once but I can't find it.
03-30-2019, 09:21 PM #242Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
FMP thanked for this post
03-30-2019, 09:32 PM #243Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Not exactly what I thought but it clearly shows the deflector ends.
03-31-2019, 08:52 AM #244Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
How about the outside corners of the inlet ports where the factory didnt drill all the way through on v4 with 4 ports.
Should you continue the machining or clean up from the piston side and angle them towards the middle?
Should help cool the deflector corners I would think?Last edited by powerabout; 03-31-2019 at 08:54 PM.
03-31-2019, 01:41 PM #245Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Finger port over top of wrist pin, favored slightly to intake side. When cutting port into block you leave just enough for ring support next to intake port (thus more support on exhaust side) then line up hole in piston to match. You can also at this point cut deflector toward exhaust, dont do this without finger ports.
03-31-2019, 03:43 PM #246Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Found a few pics here
https://www.screamandfly.com/showthr...pistons/page2&
04-06-2019, 07:09 PM #247Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
04-07-2019, 07:03 AM #248Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Powerabout if you do blend you take up area needed for finger ports, also never found gains in power by doing that.
powerabout thanked for this post
10-15-2019, 12:42 PM #249New Member
- Aug 2017
- Malta
finger ports on 84` 115 v4 crossflow.
currently building this v4 to "9 pages" specs but not altering the port heights. my query is about adding finger ports.from reading several posts on S&F i came to a general understanding of these ports and were to place them ,my question is how wide to go(i was thinking around 15mm so as to leave some beef over the 19mm g.pin in the piston!(meaning the port in the piston and the actual finger will be of the same width.!) and more importantly how deep should i go ? should i stay around 1.5mm so i don`t penetrate the steel sleeve or just keep digging to maybe 2.5mm and end up in the aluminium liner (would be way better flowing i`m guessing ??)also just to make sure others have pointed out the importance of placing the ring locating pin dead center in the finger port so as to avoid clipping any ring ends is this correct? i really dont wanna go to the trouble of relocating the ring locating pins .the pistons are low ring cast. tnx for any help!!
