Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 88
    May 2006
    SUNRISE FLA
    I was at konti ki 4 that 24 skater with crown vic he said it pulled just fine/red rocket out
  2. #17
    Jul 2004
    Connecticut
    Quote Originally Posted by David View Post
    Volvos have the highest tow ratings for cars. 2200 lb for the small cars, 3300 for the larger cars.
    If you can find a 2006 or 2007 V70 "R" Wagon they could be bought with a true factory hitch option. The slightly beefier 6 speed and the Brembo brakes up the tow capacity to 3,500 lbs.
    In a true car, as David mentions, I don't think you can get a higher towing capacity. A very nice side benefit at the ramp is the AWD.
  3. #18
    Aug 2004
    Venice, Florida
    Overseas you see boat, horse, etc. trailers being pulled by much smaller vehicles than we use in the states. Most of us have overpowered boats then worry about silly things like being a few pounds over a tow rating.
    21' Paramount
    Mercury 300 Promax
  4. #19
    JAX. FLORIDA
    My wife's Honda Pilot with 4 WD will pull a 5000 lb boat. It pulls my 2500 lb A-boat so easy that you forget it was there. Most Honda products with 4 WD will pull 5K or 3K without 4 WD.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  5. #20
    Are you sure that biel weighs more on the steel trailer then the q-shot on the aluminum? Thats surprising, I'd think they were close but if the biel is heavier I would have lost that bet.
    Tow ratings? 75mph UP the skyway 1050*F 25 PSI water/meth- OFF
  6. #21
    Oct 2013
    Palm Harbor, Florida
    Tow ratings? Tires didn't the fenders. lets role
  7. #22
    Feb 2008
    perry fl
    Mine seems to pull ok too Click image for larger version.
ID:	286328can't hardly tell when the boats behind me
    Check out my onlyfans....
    Subscriptions start at 1 gallon 100LL a month
  8. #23
    Nov 2005
    MAINE
    Quote Originally Posted by JR IN JAX View Post
    Integrated Class III Trailer Hitch
    An integrated Class III trailer hitch, tastefully hidden behind a cover, is standard on every Pilot. In addition to the integrated hitch, the Pilot comes ready to tow with a heavy-duty power steering cooler. And 4WD models add an automatic transmission-fluid cooler. The trailer harness is standard on Touring models, and available on EX-L and below models. Maximum towing capacity is 2,000 lbs for 2WD models, and 4,500 lbs for 4WD models[1].
  9. #24
    Jul 2002
    South Florida
    78 Hydrostream Vandal - under restoration here: VANDAL RESTORATION THREAD
    86 21' Eliminator Daytona
    17' Badetta sandbar skiff
  10. #25
    Aug 2004
    Venice, Florida
    Pulling our I/O though the Smoky Mountain National Park
    21' Paramount
    Mercury 300 Promax
  11. #26
    Oct 2010
    Greenwood Lake, NY
    My Pop pulls a 21 foot walk around with a Pilot about an hour to the bay without a problem. As someone else mentioned a 94 up Fleetwood Brougham (RWD) or any of the RWD GM's of the era are a good candidate. I believe 94 was the first year they came with the LT1 from the Z28/Trans Am.
    I was going so slow I almost crashed. - JamesGang
    1978 24 Superboat - 250 EFI
  12. #27
    Jun 2011
    Norcal
    Almost any car out there will pull a little 18 foot boat to the launch ramp and back. The tow ratings for late model vehicles is very underated and conservative. More important is the hitch rating that you have on the vehicle.
  13. Likes Tin Man 2 liked this post
  14. #28
    Virginia Beach
    Quote Originally Posted by Mr. Demeanor View Post
    This is because the Europeans have a totally different vehicle tow rating system than we do. First, their vehicle manufacturers, hitch manufacturers and governments are all in communication with each other and collaborate to calculate the maximum towing load of each vehicle. Second, they also collaborate to determine the only allowable hitch attachment points, and these are detailed in the "whole vehicle identification plate", which we have on US cars also but ours does not contain this information. Our vehicle manufacturers, hitch manufacturers and government do not collaborate on towing attachment points and towing ratings. In fact, the last time the VESC vehicle code committee met was back in 1983. The VESC has not been active since then. Today, the SAE is the only active body that studies towing. The Europeans also require hydraulic surge brakes on even small trailers, so this helps to provide more stopping capability.
  15. #29
    Jul 2004
    Connecticut
    Interesting overview. A great example of the folks across the pond working smarter while we buy Pickups.
  16. #30
    Jul 2004
    Connecticut
    You can also find a Saab Viggen (2000-2001) in either ragtop of coupe. These had a factory tow hitch option that is rated for 2900lbs. Now that Saab is gone, you can buy a clean one for close to nothing and they will return 30mpg while not towing.
