Results 1 to 15 of 27
Thread: clunking rear end ?
10-15-2013, 05:32 PM #1
clunking rear end ?
ok chevy guys it seems i have a clunking in the differential on my 01 silverado ?
as i rock the truck in park i hear and feel a clunk in the tire and it is slipping from a stop sign
if i go really slow and let it roll off its not as bad
any ideas
i will see tomorrow how much slop is in the pinion by turning it on flat ground in neutral
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
10-15-2013, 05:47 PM #2
universals good
10-15-2013, 05:56 PM #3
seem fine on the u joints and no squeaking at all
for sale
10-15-2013, 06:19 PM #4
http://www.youtube.com/watch?v=KbMZ9vcYVSg
i worked the chit out of it the last few weeks towing i must have hurt it somehow
or its just the 125000 miles on it now
for sale
10-15-2013, 06:56 PM #5
worn out clutches in a limited slip or posi trac rear generally does not make any noise or slippage going straight. the signs of bad clutches is a popping or catching when turning. or a crab walk feel going straight. hard to explain but when accelerating in a straight line at light throttle the rear will feel like it binding up a little then snap loose. 2 different size tires on the rear will cause it to do the same thing. if it is a steady bang,bang,bang noise could be a broken tooth on either the ring gear or pinion or both. a loud bang every now and then is usually caused by the cross pin retaining bolt sheared off. that lets the pin walk out until it hit the pinion gear and gets knocked back in. that is until it slides out a little to far and tears up everything.
10-15-2013, 07:28 PM #6
for sale
10-15-2013, 08:15 PM #7
Emergency break shoes falling apart ..... Pull the rear rotors and get a look see .... Have fun.
1990 hydrostream virage diamondpower280
10-15-2013, 08:17 PM #8
for sale
10-15-2013, 08:27 PM #9
Lol have fun with that . I use a really big hammer to get the nasty ones apart and have it down to about 5 good smacks to spit the rotors when the linings fall off the emergency shoes and lock the rotors up.
10-15-2013, 08:29 PM #10
for sale
10-16-2013, 09:26 AM #11
the leaf springs are slpping on take off
for sale
10-16-2013, 10:52 AM #12
Check the yoke that goes into the transfer case. They have issues with them clunking. My 99 half ton does it pretty bad... I did clean & grease it all and it helped.
Sure your T-Case isnt about to blow the chain out the side of it?Sunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
10-16-2013, 11:04 AM #131990 hydrostream virage diamondpower280
10-16-2013, 08:22 PM #14
for sale
10-17-2013, 05:31 AM #15
Your post seems to indicate two issues,first the "clunk" that may be a e-brake lining but sounds like maybe a spider gear pin in the diff wollerd out.The second issue "slipping"on take off,could only be a trans issue.Its dought full you have both,bad diff and bad trans at the same time.---If you could explain the slip issue a little more it may help.
