Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 81 of 81
  1. #76
    Jul 2013
    Athens, TN
    you'll see it above 65. the 4 blade prop does help stabilize the boat because there is less time between when each blade begins to cut into the water, but if you have gps id just either take it off or at least flip it up.
    1984 17vee Bullet w/1985 Johnson 150gt (bob's nose cone, hydrodynamics custom 8in. jackplate, custom skid plate and foil, and 26p trophy plus) currently 70mph tournament loaded.
  2. #77
    Oct 2013
    Mammoth Cave Kentucky
    Ok. What did u thk about the underneath shots of my water pickup.
  3. #78
    Jul 2013
    Athens, TN
    it an interesting bolt on products but that lip at the edge of the plastic case is large for what it is ment to do. it will creat a turbulant spot right there which could be dangerous at high speeds. the intake is massive but what really matters there is your water pressure. Thats the biggest factor is watching your water pressure and making sure it stays at the correct levels.
  4. #79
    Oct 2013
    Iv always got good psi since I put it on. It did have the top two hold plugged but wasn't getting the pressure it needed. He set the alarm off when I test drove it. And because of that I got it 500 cheaper than before we went out in it.
  5. #80
    Jul 2013
    Athens, TN
    hey im all for a good deal i picked mine up for 2600. i think i have spent another 1800?
  6. #81
    Oct 2013
    I gave 3500 put hydro steering humming bird side imaging black light jacks and made a wind screen for it cause you can't buy one for it. I want a minn kota with I pilot and then I'll be done for now. I always wanted a bullet and I'm tickled pink with mine. It isn't new but it's set up like I want it.
