Results 1 to 8 of 8
    Aug 2005
    Ontario, Canada
    Removing decals/stickers from Johnson Cover.
    I am going to be removing the original 1981 Johnson decals/stickers from my motor cover and replace with new ones. From searching on this site I have decided to use a heat gun to remove and then use WD-40 to remove any left over glue or adhesive as not to damage the paint.
    Here is a spare cover I am going to practice on.
    Any suggestions or ideas most welcomed.
    Regards.
Name:	75 hp decals.jpg
    Sep 2002
    I'm pretty sure the "paint" under the decals is gel coat, which solvents typically will not damage. I could be wrong...
    Aug 2005
    Ontario, Canada
    Quote Originally Posted by pyro View Post
    So I could wipe the decals with mineral spirits to help remove - they are somewhat sun baked and probably will be tough to get off.
    Jun 2011
    South FL
    A rubber wheel works well too.
    2004 Deep Impact 36 Triple 300 Verados
    1998 Donzi 35 ZFC Triple 300 Verados FOR SALE
    1989 24ft Skater, Twin Diamond Marine 280's with Diamond Tuners, 34p Cleavers. A few pieces of JL Audio equipment.- SOLD
    1988 18ft Talon- SOLD
    Jun 2011
    Norcal
    Use an eraser wheel. They can be purchased at an auto body supply store. Run it on a drill at slow speed.
    Aug 2005
    Ontario, Canada
    Quote Originally Posted by F14 View Post
    Can I assume the eraser wheel won't hurt the paint if you are careful and go at slow speed?
    I will see if I can purchase an one this week and try it on the weekend - thanks!
    Jun 2011
    Norcal
    No it wont hurt the paint. It is a slow process, take your time.
    Beautiful Lutz Florida
    I Just Removed The Original Decals From My 89' Allison XR02...$12.00 Duel Heat Heat Gun From Harbor Freight!!! Workes MIRICLES! Got 90% Of The Glue Off With The Decals Took Probably 30-min. Tops! Use The Cooler Of The Temps Or You Will Be Lookin' In The Parts Wanted For A Cowl Though....Just Sayin' The Hotttt Setting Isn't Kiddin'!!!
